Forums >> Revit Building >> Technical Support >> Extended wall face around Door-Window
29 Posts No Rating |
Finally, I posted them... I need to make 1 more family for this wall projection which runs along the wall. Please look at the attached image. The extanded horizontal wall projection which runs above the stone clading... How can I make it's lenght variable??? Which I can adjust in project. (i.e. small blue triangle in another image which i can drag and change the length. ) Thanks.
Use the "Wall Sweep" to do that, create a "Profile" family with the shape you want, then go to the properties of the wall>Edit/new and in "Section" you can add a "Sweep", check the HELP menu..... Also, search here in the forum for "Wall sweeps", there are lots of thread about this...
Thanks Typhoon, I created the wall sweep for this. It was little bit complecated to load it in project and then load it in wall sweep category by changing the property and creating new sub category... etc.... But, i read in Help and tried my best to figure it out. This is good Idea to use the sweep vertically & Horizontally. you are awesome!!! If you have time, can you please check my another thread, called "different Material/Paint/Texture/Finish to inside and outside faces of the wall"? Please guide me how to change the color of the exterior texture which I picked. (I use Revit Architecture 200 . Thanks a lot..
Flip door swing direction without flipping its location in the wall |
Thu, Feb 18, 2021 at 4:13:27 PM
how do you set a window back from the face of the wall of an exisitng window? |
Tue, Mar 13, 2012 at 10:36:59 AM
windows offset from face of wall |
Fri, Jul 14, 2006 at 5:03:24 PM
Stop Revit from Painting outside of Split Face region |
Wed, Feb 12, 2025 at 4:12:50 PM
Wall and Window problems please help |
Tue, Jul 8, 2008 at 10:21:30 AM
Members: | 2114708 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
