Forums >> Revit Building >> Technical Support >> Hiding Detail Tags in other views
13 Posts No Rating |
d00d - nevermind. You obviously arent getting what anyone said in this thread. I have "types" for every kind of detail there is. Window/Door details, Roof details, Accessibility, Partition.....etc you still cant control them through a visiblility setting...you have to hide the individual types per view...not controlled through view templetes.
Apologies - missed the bit about the views being the same scale. What I suggested will only work for different scale views.
Its all good - I appoligize for taking my revit frustrations out on you.
41 Posts No Rating |
im probably way too late here, but what you do is highlight all the details/sections etc in the project browser that you dont want to see in floorplans, then right click and properties menu. then select hide at scales coarser than 1:1. this will hide the reference tag in any view that is larger than 1:1 (unless you have a 1:1 scale view which is unlikely) you definitely need the power to do this otherwise it would take ages
OMGWTFBBQ? - Did you even read the whole thread?
whoops, i missed that. probably cause it was hidden amongst all your other bickering mate if you post something on here and then bite the hands that try to feed you, you will get nowhere fast!
THE CHAT ROOM FEEDS ME AND IM ALRIGHT BY THAT....HENCE THE REASON I HAVE 10 POSTS IN THE FORUMS IN THE PAST 3YEARS...... THE ONLY BICKERING THERE WAS, WAS ME TELLING PEOPLE TO READ THE THREAD B4 POSTING! :EYEROLL: AND JUST TO CLEAR IT UP - YOU CAN NOW SORT/HIDE SECTION/ELEVATION/CALLOUT TAGS BY TYPE IN VG SETTINGS IN 2010....OR SO IVE BEEN TOLD...STILL USING 09 ----- BUT WHAT DOES IT MATTER? NO-ONE WILL READ THIS ANYWAY!
Hiding a detail in all views in one step |
Thu, Jan 21, 2010 at 2:04:15 PM
Interior Elevation Tags in Detail Plan Views |
Tue, Nov 9, 2010 at 8:06:18 AM
Detail / Drafting Views |
Thu, Nov 29, 2012 at 9:18:20 PM
additional detail tags |
Thu, Apr 19, 2012 at 3:27:32 PM
Detail components in multiple views. |
Tue, Aug 18, 2009 at 2:46:36 PM
Members: | 2098617 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
