Forums >> Revit Building >> Technical Support >> looking for .pat files
Thank you Typhoon.
Purushothaman Munusamy
www.cddsindia.com |
Need help making this pattern for a .pat file.
The pat file attached is what I have been able to get so far. Can't figure out how to space the angles.
Edited on: Mon, Nov 30, 2020 at 3:47:20 PM
Can you post a picture of the pattern look you are going for. it is not clear from the .pat you posted.
Sorry I originally posted it but I didn't notice when I edited the post it took it away.
This is what I have so far and what it needs to look like. I can't figure out the offset/ shift spacing.
Here is the pattern that works. I made the tiles 2" wide x 8" long as that is alot easier to work with for numbers rathr than the 1.83 you had the lines at in your attempt.
*WT-3
;%TYPE=MODEL
90, 0,0, 0,2
45, 0,0, 5.65685424949238,5.65685424949238, 2.82842712474619,-8.4852813742385
45, 4,0, 5.65685424949238,5.65685424949238, 2.82842712474619,-8.4852813742385
-45, 2,2, 5.65685424949238,5.65685424949238, 2.82842712474619,-8.4852813742385
-45, 6,2, 5.65685424949238,5.65685424949238, 2.82842712474619,-8.4852813742385
I figure it out. Iposted my last response before you had sent the screenshot with the dimensions. It was a lot more complicated because of the distance betreen the lines that actually line up on the angle which dictates the penup pendown distances.
Wow Thank you so much! I would never got all that! LOL
Here is a visual representation for line patterns. The main trick with angled lines is that the shift and offset rotate with the line. The origin always stays as 0 and 90 for the planar directions.
Thanks, I have one similiar but this one is better. I will practice more until I can conquer it! Thanks again.
Pat Files |
Thu, Jan 22, 2009 at 1:26:47 PM
Use Pat Files |
Tue, Sep 1, 2009 at 4:18:40 AM
11
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder? |
Mon, Jul 6, 2015 at 11:01:26 AM
custom pat files |
Fri, Oct 21, 2005 at 3:13:23 PM
Pattern (.PAT) Files |
Mon, May 3, 2021 at 4:51:04 PM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
