78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Render Calculation Error?
Mon, Mar 16, 2009 at 5:43:39 AM | Render Calculation Error?
#16
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
what was this thread about anyway- oh yeah rendering..
starting two years ago i was one of many who asked
in the autodesk forums why revit had
such a crappy rendering engine.. lol
finally they did something about it..
MentalRay is so awesome.. it still amazes me..
now i can actually see my models..
Sun, Apr 26, 2009 at 12:00:21 PM | Render Calculation Error?
#17
rockstonne
Hey guys, I'm having the exact same problem as kripple51. I'm hoping that since this was posted about a month ago that someone found a solution. I also did update 3 for Revit 2009.
System stats: Vista Home Premium, Core 2 Duo T7500 @2.2GHz, 3 GB RAM, Total Virtual Mem 6.19GB Availiable Virtual Memory 4.29GB.
I went as far as to DL Revit 2010 but along with other issues I got the same problem. The only time my rendering operated as normal is when I deleted part of my massing. This is obviously an undesirable solution. Any help will be appreciated.
Thanks
Wed, Feb 17, 2010 at 12:31:14 PM | Render Calculation Error?
#18
allisonkapler
I am having the same problem, I am rendering an aerial site plan, there is no sky visible in the rendering, could this be part of my problem? I am also running vista, but have done tons of renderings with no problems, just the two aerial shots I need to render, renders about 10% and then gives me the errorr "Unknown error during rendering calculations. The rendering operations will be cancelled."
Fri, Jun 7, 2013 at 7:25:58 AM | Render Calculation Error? same here...tomo is my JURY!!!
#19
RevitHatter
i am not able to reder anything Sad mine is a large building.. can you give me the link to the update with which i can render? i need to get rints tonight...so please reply ASAP!
Sad Sad
Fri, Jun 7, 2013 at 7:53:38 AM | Render Calculation Error?
#20
3.5 Stars: 395 Votes
You have not told us anything about your system or your problem.  This thread was from 2009 and a completely different render engine.
Without knowing anything more, I suggest you use ccleaner to clean your temp directory.  A full temp directory often causes render problems.
Stair Material Takeoffs - Volume Calculation Error when Painting
Tue, Dec 10, 2013 at 7:45:46 AM
Error: Revit was unable to render the view due to an unknown error.
Mon, Apr 28, 2014 at 3:32:17 AM
Render Error - "Unknown Error during Rendering Calculations"
Fri, May 1, 2009 at 1:52:23 PM
help: why do I get a server error when I try to render revit in iCloud??
Tue, May 20, 2014 at 12:58:46 PM
Error in RAC 2009-RENDER
Thu, May 22, 2008 at 4:28:46 AM
Page generation time: 2.4579
