45 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Water Trick
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
This rendering also done with a floor of water material.
You can dial up or down the waves with the water material.
This is a shallow reflection pool.
The pool lights have a nice effect at night.
![RainaMc Avatar](user_avatar/72958.jpg)
126 Posts No Rating |
Tim 123 and Erland73,
Can you guys please help me out? What material settings did you use for your water? The water in my renderings just look green like someone needs to clean the pool.
Thanks,
1 Posts No Rating |
Sorry, but I am a bit new to Revit. I have the opposite problem. I am doing a lrage site plan in 3D and when I do a 3D image in realistic mode I want the sea to be non transparent. Can not seem to do it. any suggestions?
Change your material settings for the water you are using.
Hallo!
I am rendering an exterior perspective in Revit 2014 and my lake seems very unrealistic.
There is very little reflection.
I created the lake surface with a floor 800mm thick.
At the bottom of the lake I have a white material.
I didn t manage to find where can I adjust the reflection of the water material.
And generally, I would welcome tips to make the water seem more real..
![Sad](/images/smiles/sadley.gif)
Edited on: Wed, Oct 1, 2014 at 12:15:38 PM
![4.5 Stars: 2 Votes](/images/stars_4.5.gif) |
fresh water, no one has bathed yet
I made using the same methord which is eiher floor or ceiling both will work. take your time to use defferent methords. it will work, change the volume of waves and try
modeling body of water (2017) |
Fri, Mar 3, 2017 at 10:19:37 AM
Pool Water Green in Rendering |
Thu, Feb 16, 2012 at 1:17:13 PM
Water / Site - Water material problems |
Mon, Mar 31, 2014 at 10:37:00 AM
Domestic Hot water - No flow |
Fri, Dec 11, 2009 at 3:50:05 PM
Squatting Water Closet |
Wed, Dec 7, 2011 at 11:31:34 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
