64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Repeatig wall sweep vs. repeating detail - wall attached
There it is... check the properties of the "Curtain Wall".....
29 Posts No Rating |
An elegant solution indeed. In order to show the rest of the wall, (the membrane, sub-strate, studs, and inteiror finish), I could join the exterior finish curtainwall with a wall with the rest of the pieces.
That's the idea, create the wall like you want but don't put sweeps then create the "curtain wall" in the exterior.... then when you "Cut" you have the Total "With" of the wall....
That's an interesting work-around. Thanks for the attention.
See attached. It works well. Thanks!
Non-Continuous, Repeating Wall Sweep |
Wed, Jun 29, 2011 at 10:49:55 AM
repeating detail hatch |
Thu, Feb 7, 2008 at 4:09:05 PM
Repeating Detail Properties |
Tue, Oct 23, 2012 at 6:59:15 PM
Repeating Detail Items |
Sun, Aug 30, 2009 at 9:22:55 AM
Setting Wall Sweep to Detail Levels |
Tue, Jun 9, 2009 at 10:14:20 AM
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
