136 Users Online (134 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2009 Rendering Problem(Black screen)
Mon, Jan 5, 2009 at 9:07:56 AM | Revit 2009 Rendering Problem(Black screen)
#16
Haus
4.5 Stars: 3 Votes
Hello unn7,
I have the same problem, did you have found a solution?
the render in RAC 2009 is a image totally black, it takes just 1 second to complete. Can you help me?
Thanks
Mon, Jan 26, 2009 at 10:29:56 PM | Revit 2009 Rendering Problem(Black screen)
#17
maggotdude
4.5 Stars: 13 Votes
help!!..i also have the same problem..
Thu, Mar 12, 2009 at 10:56:22 PM | Revit 2009 Rendering Problem(Black screen)
#18
jen7756
I have been having this problem for the last two hours and I never found an answer online...so on my own I finally figured out the issue I was having rendering an interior space in RA2009 (it was completely black).  Mine had to do with the material set for glazing.  Change this and make sure it's not on default:  go to Settings<Materials, scroll down to "Glazing" and go to the Rendered Appearance tab.  Change the Rendered Apperance Based On setting to something that is actually transparent, i.e. Glazing.
I hope this helps a lot of others having the same issue I did!
Tue, Apr 14, 2009 at 11:01:30 AM | Revit 2009 Rendering Problem(Black screen)
#19
profbrody
I've seen the same problem - it's perplexing, but has been occuring with models created in older versions of Revit. Some older interior lighting components might need to be updated to 2009 ones. Select the compent, get it's Properties, and then click Load. Find the same component in your 2009 Imperial Library, and load it in. Allow it to replace the existing one. That seemed to work with downlights, anyway.
 Another problem I've been having after upgrading is that Revit forgot that the "glass" material's render appearance assignment. It makes all the windows gray, so no light come in...
 If anyone knows a quick fix for these lighting annoyances, I'd love to hear about it!
Mon, Jul 13, 2009 at 2:51:18 PM | Revit 2009 Rendering Problem(Black screen)
#20
smithth
My Solution:
I set up a camera on level 1, but lowered my view below level one [I was trying to render a scene from a lower level, level 0 we will call it].  I think the rendering was black because it throught I was in the ground, but I had actually created a floor that was 15" lower than level one.  I went back to level 0 floor plan pulled a camera from the same angle and everything worked perfectly.
All I had to do was un-bury myself.
Tue, Nov 30, 2010 at 1:21:04 PM | Revit 2009 Rendering Problem(Black screen)
#21
ckorenic
I had a simmilar problem with a rendering and as strange as this sounds the problem ended up being the type of tree I had in the model (Red Ash). When I removed or changed the tree the problem was solved.
Mon, Apr 1, 2013 at 12:13:09 PM | Revit 2009 Rendering Problem(Black screen)
#22
reham
I'm a student and I suffer from the same problem and I do not know I Masbb want a solution to this problem
Mon, Apr 1, 2013 at 12:25:42 PM | Revit 2009 Rendering Problem(Black screen)
#23
4 Stars: 202 Votes
It's an "Interior" Render with "Sun only", did you have any light in there? Did you active "Portal Daylights"?
Mon, Apr 1, 2013 at 12:41:11 PM | Revit 2009 Rendering Problem(Black screen)
#24
reham
Yes, there have lighting but all attempts the same result
Mon, Apr 1, 2013 at 12:47:39 PM | Revit 2009 Rendering Problem(Black screen)
#25
That image says sun only!!!!!!
You have to turn on your lights and they can't be hidden by a ceiling.
Perhaps you should post the view before you render so we can see what you have.
Mon, Apr 1, 2013 at 12:55:10 PM | Revit 2009 Rendering Problem(Black screen)
#26
reham
This prior work render
Mon, Apr 1, 2013 at 1:56:44 PM | Revit 2009 Rendering Problem(Black screen)
#27
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This is an exterior view so you should be using EXTIEROR Sun not interior
Mon, Apr 1, 2013 at 2:45:29 PM | Revit 2009 Rendering Problem(Black screen)
#28
reham
But I worked the same outcome
black screen and unfinished renders
Tue, Apr 21, 2009 at 7:28:18 PM
Rendering Revit Architecture 2009 - Little Black dots!!!!
Fri, Dec 19, 2008 at 5:42:50 AM
Revit Black Screen of Death?
Wed, Jul 15, 2009 at 8:53:06 AM
Black annotations on black screen
Mon, Jun 20, 2016 at 2:18:40 PM
Black Screen Problems
Tue, Jan 12, 2010 at 8:24:34 PM
Page generation time: 2.2139
