80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> mysterious hole in wall
19 Posts No Rating |
apparently in phase 2 we have a wall there. ahhhh thanks!
Something similar to this poped up on AUGI last week. Are you useing Revit Arch or Revit Str? By default Revit Str does not show non bearing walls. You would need to turn your visibility setting to "coordination" instead of structural. Then all of the architectural objects will appear, otherwise you just see structral elements. According to Revit only bearing walls are strutural; not that this is actually correct but thats the way that revit thinks. Alternatly you could have something hidden in plan or someone could have drawn a shaft. Shafts will penetrate through wall walls, floors, etc from their top to bottom. Sometimes they can be a pain to find if you dont know where (what plane and view) they were drawn. You may be able to find it by selecting everything and filtering in that view. Otherwise try the yellow lightbulb and see if you have something hidden... HTHNick
Applying Materials To Cover A Hole |
Mon, Mar 10, 2008 at 8:26:30 PM
Curtain wall in wall hole |
Tue, Sep 8, 2009 at 7:03:33 PM
Mysterious Notch in Wall |
Tue, Dec 14, 2010 at 4:29:42 PM
cutting a hole in a massed floor/roof |
Mon, May 11, 2009 at 7:07:00 AM
Cutting a shaft wall |
Thu, Nov 29, 2012 at 7:13:39 AM
Members: | 2017247 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
