134 Users Online (133 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> create a custom fill pattern
Wed, Oct 12, 2016 at 9:16:11 AM | create a custom fill pattern
ledgewood33
i have this cmu pattern that I would like to make a fill pattern. wondering what the best way to go about getting this done. I have attached a .dwg with lines & dimensions that represent the pattern I would like
Wed, Oct 12, 2016 at 1:16:15 PM | create a custom fill pattern
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Enjoy.
Wed, Oct 12, 2016 at 1:34:54 PM | create a custom fill pattern
ledgewood33
thank you very much. very greatful
Fri, Sep 8, 2017 at 8:55:18 AM | create a custom fill pattern
jessicavuocolo
I have a custom pattern that I drew in AutoCad too, any chance that someone can run it through a pattern creator
Fri, Sep 8, 2017 at 1:36:04 PM | create a custom fill pattern
blue442
blue442 Avatar
Here you go.
.Pat file and a .dwg with it inside it.
Fri, Sep 8, 2017 at 2:44:05 PM | create a custom fill pattern
jessicavuocolo
Thank you very much - I get an error message that the pattern values you have supplied is too large. Try decreasing the line spacing values?
Fri, Sep 8, 2017 at 2:54:19 PM | create a custom fill pattern
blue442
blue442 Avatar
draw it to scale and i'll convert it to a model hatch for you...
you can simply change the import scale factor to .15 and it will work when importing it otherwise...
but... I have no idea how big you want this.  I used the real dimensions you used to convert it.
Fri, Sep 8, 2017 at 3:08:02 PM | create a custom fill pattern
jessicavuocolo
The original file that I posted was to scale. the pattern that you created looked perfect in CAD but for some reason the .pat file that I plugged in doesn't work.
Fri, Sep 8, 2017 at 3:08:46 PM | create a custom fill pattern
jessicavuocolo
Fri, Sep 8, 2017 at 3:11:57 PM | create a custom fill pattern
jessicavuocolo
Fri, Sep 8, 2017 at 3:12:09 PM | create a custom fill pattern
jessicavuocolo
Fri, Sep 8, 2017 at 3:15:38 PM | create a custom fill pattern
blue442
blue442 Avatar
There are limits for revit and hatch patterns.
you can read up on them here... but you'll have to modify the hatch pattern to make it work for revit.
http://www.hatchkit.com.au/faq.php#Tip7
**Edit
the hatch was in inches right? i assumed it was, if it was not, that might be part of the problem.
Edited on: Fri, Sep 8, 2017 at 3:17:09 PM
Fri, Sep 8, 2017 at 3:21:39 PM | create a custom fill pattern
#13
jessicavuocolo
yes the hatch was in inches - the pattern works if I scale it down but it is a large scale repeat. The overall size of the octagon is 5' x 5'9" and the connecting rectangles are 6" x 12"
Fri, Sep 8, 2017 at 3:28:35 PM | create a custom fill pattern
#14
jessicavuocolo
Fri, Sep 8, 2017 at 3:32:45 PM | create a custom fill pattern
#15
blue442
blue442 Avatar
not sure this effects it, but... i'm not sure its draw right... i am not seeing clean dimensions as you listed.
I'll run another pass over it if i have a chance before i leave.  Otherwise i'll look at it monday.
Stray Lines in custom Revit fill pattern
Mon, Jul 8, 2013 at 8:02:44 AM
Custom fill pattern with a background
Mon, Jul 24, 2017 at 8:01:44 AM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
fill pattern alignment
Sun, May 3, 2009 at 1:28:15 PM
Page generation time: 2.1592
