70 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Crop Region Line Control
Wed, Mar 23, 2016 at 11:00:32 AM | Crop Region Line Control
glenlake
3.5 Stars: 3 Votes
Dear colleagues!
Please advice if their is a way to change the thickness and color of the Crop Region Line - say, i want it to be printed and have Bright blue Color and weight 7.
How can I do it?
 Thank you.
Wed, Mar 23, 2016 at 12:23:24 PM | Crop Region Line Control
No way that I have ever seen.  This is a system setting.
Wed, Mar 23, 2016 at 5:04:49 PM | Crop Region Line Control
glenlake
3.5 Stars: 3 Votes
Thanks a lot. You saved plenty of my time.
 Best regards,
  G
Thu, Mar 24, 2016 at 3:23:07 PM | Crop Region Line Control
glenlake
3.5 Stars: 3 Votes
I changed it, but i don't know yet how.
I will let you know if i find it.
 Regards,
 G
Thu, Mar 24, 2016 at 3:32:51 PM | Crop Region Line Control
Johnzo142
Select the crop region boundary and override by element. Change the color and thickness there and un-check hide crop boundary in your print settings.
Thu, Mar 24, 2016 at 3:56:07 PM | Crop Region Line Control
glenlake
3.5 Stars: 3 Votes
Thanks. I think i did it by overriding the thing in view. Fail.
Fri, Mar 25, 2016 at 9:23:00 AM | Crop Region Line Control
Johnzo142,
You should always test your answer first.  I tested that before I answered and you can not override element for crop region lines.
Fri, Mar 25, 2016 at 9:45:23 AM | Crop Region Line Control
Johnzo142
I did test it before my answer and it most certainly does work. I even printed my test prior to answering to ensure that the color came through. I'm not in the office at the moment or would post a screen shot.
Fri, Mar 25, 2016 at 9:55:15 AM | Crop Region Line Control
Here is my image
Fri, Mar 25, 2016 at 9:58:13 AM | Crop Region Line Control
Johnzo142
Strange, that's not what I got. I did it from an active view on a sheet, perhaps there is where the difference is.
Edit: Nevermind, I see from your image that you are in an active view on a sheet. I'll post my image later.
Edited on: Fri, Mar 25, 2016 at 9:59:29 AM
Sat, Mar 26, 2016 at 12:44:02 AM | Crop Region Line Control
#11
glenlake
3.5 Stars: 3 Votes
So, i see that the only way to change the crop region color is to override it in view.
What i wanted was to change it globally through Object Styles.
Thank you again for your help.
Mon, Mar 28, 2016 at 9:21:25 AM | Crop Region Line Control
#12
Johnzo142
Just to follow up, it appears that the override by element feature is not available for a plan view but is available for section and detail and elevation views. WWHub, this is where the difference was. glenlake, you are correct that there is no way to control this globally.
Edited on: Mon, Mar 28, 2016 at 9:22:56 AM
Mon, Mar 28, 2016 at 12:35:40 PM | Crop Region Line Control
#13
Johnzo142,
I have to apologize, I was just being stupid.  I think I had used the crop region over-ride several years ago and had forgotten because we turn off crop regions when printing in our office.  When I checked it for plans, it was not available and I failed to check it for sections and elevations.   Revit has changed so much over the years and I did not follow my own advice.
Mon, Mar 28, 2016 at 11:52:07 PM | Crop Region Line Control
#14
glenlake
3.5 Stars: 3 Votes
Why is it so?
Is it so overcomplicated for the softwaer developers that they could not make it controllable through Object Styles?  It's obvious that the feature could be extremely useful when you work with sheet layouts.
Or is it made intentionally? But why?
 Any thoughts?
Tue, Mar 29, 2016 at 7:52:20 AM | Crop Region Line Control
#15
There is a wish lit maintained by AUGI and this issue may be on it.  You can add it if not.  AUGI has a vote every so often and they submit the results to Autodesk.  I think they do pay attention ...somewhat?
crop region - elevations
Fri, Oct 23, 2009 at 12:43:33 PM
Macro for changing lineweight of crop region
Wed, Jul 22, 2015 at 10:05:22 AM
Dimensions & Crop Regions
Mon, Sep 18, 2006 at 9:56:41 PM
Annotation lines outside the crop region
Thu, Jun 16, 2016 at 8:55:13 AM
Crop Region Line Weight
Mon, Nov 24, 2008 at 10:32:53 AM
Page generation time: 2.6583
