65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering Modeled Siding
Fri, Aug 24, 2012 at 10:40:06 PM | Rendering Modeled Siding
ml22
I have modeled siding on some walls using reveals.  The dimensions are accurate, using Hardie Plank as a product.  The effect works well, except when rendered.  The texture is so slight that it is almost invisible.  Anyone know how to make it more visible without going (way) beyond the actual depth of the product?
Sat, Aug 25, 2012 at 5:37:30 AM | Rendering Modeled Siding
4 Stars: 201 Votes
Post some images, in shaded and rendered....
Tue, Aug 28, 2012 at 10:33:27 PM | Rendering Modeled Siding
ml22
Shaded and rendered images attached.  You will notice that in the rendered version, the siding edges are invisible, except that their relections appear in the (aluminum foil) metal roofing below.
 I did try increasing the depth of the profile.  These images were made with the siding at 4x actual depth (1 1/4").
Wed, Aug 29, 2012 at 3:36:57 AM | Rendering Modeled Siding
4 Stars: 201 Votes
You can create that effect with a simple "Texture", no need to use reveals....
Thu, Aug 30, 2012 at 10:07:09 PM | Rendering Modeled Siding
ml22
I don't have an easy way to modify the color of an image to use as a texture.  If the wall itself has the profile, I can modify the color of the wall surface easily by changing the material's color.
Fri, Aug 31, 2012 at 8:17:28 AM | Rendering Modeled Siding
AbsoluteBIM
AbsoluteBIM Avatar
3.5 Stars: 3 Votes
I agree with Typhoon; I've tried modelling siding accurately and it just bogs down the model.
Have you tried applying a "bump" pattern to your material instead? I've created some custom bump patterns similar to what I attached that I use for different siding patterns.
Fri, Aug 31, 2012 at 4:51:32 PM | Rendering Modeled Siding
Johnzo142
This is one that I did recently by using a color and turning the image fade down and the bump up on a standard material. I was very happy with the results.
Fri, Aug 31, 2012 at 4:53:07 PM | Rendering Modeled Siding
Johnzo142
Here is the entire image.
Fri, Aug 31, 2012 at 11:30:09 PM | Rendering Modeled Siding
ml22
Johnzo,
Thanks for the advice.  I'm afraid I cannot duplicate your results, even when matching your settings.  Image attached.
I'm willing to take a little bog in the render time, if the results are right.  I'm disappointed that Revit cannot accurately render the elements when truly modeled, or even when exaggerated.
Sat, Sep 1, 2012 at 4:31:24 AM | Rendering Modeled Siding
4 Stars: 201 Votes
Choose the right texture and change the color like you want.
Render in High quality 300 DPI and check if you have the result you want.
Edited on: Sat, Sep 1, 2012 at 4:37:14 AM
Sat, Sep 1, 2012 at 5:50:30 PM | Rendering Modeled Siding
ml22
Typhoon,
The key may be that the Generic - Color is white and the hue is selected using the Tint Color variable near the bottom of the editor.  My dialog box does not have this, nor does my dialog box look like yours.  Which version of Revit are you using.  I'm still on 2012.
Fri, Sep 7, 2012 at 8:28:19 PM | Rendering Modeled Siding
ml22
Typhoon:
I need to know if this solution is available to me.  From which version of Revit was the screen shot taken?
Thank you,
ml22
Sat, Sep 8, 2012 at 3:13:43 AM | Rendering Modeled Siding
#13
4 Stars: 201 Votes
Was in 2013 and now in 2012....
A good "texture" can produce the effect you want without increase the file size.
Mon, Sep 10, 2012 at 9:57:41 PM | Rendering Modeled Siding
#14
ml22
Typhoon,
Attached is my best rendering with that method.  As you can see, the siding is barely visible (or not visible).  I have tried meddling with the degree of light and shadow, etc. to try to enhance the contrast and visibility of the siding, without success.
Any other suggestions?
Thanks.
Mon, Sep 10, 2012 at 10:31:06 PM | Rendering Modeled Siding
#15
Warchitect
4 Stars: 5 Votes
Just to ask a dumb question, but did you use a good hi-res setting while doing all the test images you said in the above post? it seems to me typhoon has his settings dialed in, and maybe youre settings are set diffy or something.
rendering horizontal wood siding.
Wed, Aug 5, 2009 at 10:49:00 AM
Showing Horizontal Lap Siding correctly in Rendering
Mon, Jan 23, 2023 at 2:41:29 PM
Looking for source of metal siding rendering patterns.
Thu, Mar 22, 2007 at 7:40:40 PM
Metal siding
Mon, Mar 16, 2009 at 9:44:10 PM
Wall Sweep/Siding
Sun, Feb 17, 2008 at 12:11:00 PM
Page generation time: 0.5100
