76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Rendereing
Search this ThreadSearch this Thread | Page 1 of 3 | 1 | 2 | 3 Next >>
Sat, May 19, 2012 at 10:31:51 PM | Rendereing
Paulinak73
Hi!
I'm finishing my space and I did the test rendering...looks like there is a reflection of the windows and some wall on the floor. I thought I made the floor shiny by mistake, but i checked the material and it's carpet. Why do I get the reflection?? Too many lighting fixtures?
Sun, May 20, 2012 at 5:31:35 AM | Rendereing
4 Stars: 201 Votes
Post some images of that so we can figure....
Sun, May 20, 2012 at 3:29:36 PM | Rendereing
Paulinak73
Mon, May 21, 2012 at 8:04:13 AM | Rendereing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you sure your floor is carpet? And in the material there is no Reflectivity checked?
Mon, May 21, 2012 at 11:10:18 AM | Rendereing
Paulinak73
Yes, Im sure... I even checked it to wood, just to test it out- I got the same effect - complete mirror reflection of windows, celong and walls Crying
Mon, May 21, 2012 at 11:24:37 AM | Rendereing
4 Stars: 201 Votes
Don't you have two (2) floors in that? one inside the other? Show us a picture with the material / properties of that floor please.
Mon, May 21, 2012 at 1:32:51 PM | Rendereing
Paulinak73
you mean two different flooring materials? the first rendering i did looks fine. i had concrete flooring in my lobby area and it rendered ok. in the area im showing you i have carpet, now changed to wood. whatever area i render, it showes me the mirror reflection of the upper side (ceiling, windows, walls etc). im attaching the first pic.
Mon, May 21, 2012 at 1:55:20 PM | Rendereing
3.5 Stars: 395 Votes
Do as Typhoon suggests and post an image of your material properties.  You have either defined the material as reflective or you have not really assigned what you think.
The material name means nothing.  You can call a material concrete but it could be set to be transparent.
Mon, May 21, 2012 at 2:40:18 PM | Rendereing
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Hey--I think it looks awesome like that.  Very 2001 A Space Odyssey.
But check your material settings.  There is a slider bar called "Glossiness".  Make sure it's set to zero.   It's independent from "reflectivity" but does the same thing.  Makes sense, huh?  If you do NOT have a materials option bar like this.... well... make/alter an existing "Miscellaneous" material to be your carpet.  You get more options with miscellaneous materials.
...I know, it makes no sense.  I have never figured out the 2012 material manager.  Most counter-intuitive interface.
Mon, May 21, 2012 at 2:56:18 PM | Rendereing
Paulinak73
Here is the print screen of the properties of the flooring - i changed it to wood now.
Mon, May 21, 2012 at 3:03:20 PM | Rendereing
#11
That is a semi-gloss so it will be reflective.
Mon, May 21, 2012 at 3:09:31 PM | Rendereing
#12
Paulinak73
so what do i change it to??
Mon, May 21, 2012 at 3:20:05 PM | Rendereing
#13
itsmyalterego
4 Stars: 16 Votes
"unfinished" should be an option for wood.
Mon, May 21, 2012 at 3:34:33 PM | Rendereing
#14
Paulinak73
Ok, looks like I got a bug Crying Nothing works . Thanks for help, anyway.
Mon, May 21, 2012 at 3:41:14 PM | Rendereing
#15
itsmyalterego
4 Stars: 16 Votes
unfortunately (or infuriatingly, at least,) everything has an explanation.   I've only written a little handful of things off to bugs.
It'll have to be a process of elimination to figure out what's wrong with your floor I'm afraid.  I would start by changing it to a material you KNOW is not glossy, and go from there.  Best of luck.
rendering light source
Mon, Dec 19, 2011 at 3:21:42 PM
Renderer Plugin for low end school laptop
Tue, May 13, 2014 at 6:06:26 AM
"Render" button greyed out
Mon, Feb 15, 2010 at 1:57:13 PM
Revit VS. ADT2005
Mon, Apr 4, 2005 at 9:23:20 PM
Page generation time: 0.2039
