53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> transparent roof
Tue, Nov 15, 2005 at 4:05:17 PM | transparent roof
swarch
i cannot figure out why my roofs are now see-thru. this changed during the course of constructing and editing the model but, for the life of me, I don't know what caused this change. Anyone have ideas?
Tue, Nov 15, 2005 at 5:01:55 PM | RE: transparent roof
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Check the material that is applied to the roof... You may have adjusted the material that the roof was using and thus made it transparent. Reset the material and make sure the transparency in the material settings is set to 0.
Tue, Nov 15, 2005 at 6:47:21 PM | RE: transparent roof
swarch
The second floor (w/ roof), elevations and 3D views look correct, only the roof plan is transparent. Strange.
Tue, Nov 15, 2005 at 9:01:37 PM | RE: transparent roof
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Make sure your not in wireframe...
Tue, Nov 15, 2005 at 10:15:57 PM | RE: transparent roof
Audrie
I have the same thing in my first project but not the others. It just changed to transparent in for some reason - obviousl something I did inadvertently. I found it very useful at first because it allowed me to see exactly what was where, but then I found nowhere to 'turn it off'. The model is definitely in 'Shading with edges' and all layers of the the roof material are set at 0 transparency. If you find out what it is, swarch, please let me know.
Wed, Nov 16, 2005 at 3:02:25 AM | RE: transparent roof
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Post a screenshot...
Wed, Nov 16, 2005 at 4:34:05 AM | RE: transparent roof
Audrie
Okay - here is an 3d Aerial of my Arthouse with this crazy transparent roof... Smile
Wed, Nov 16, 2005 at 5:04:16 AM | RE: transparent roof
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are you sure someone hasn't used the paint tool to paint on a different material to the roof that is overrighting the standard settings?
Wed, Nov 16, 2005 at 10:32:14 AM | RE: transparent roof
ATisue
Speaking from prior experience in a situation similar to this..... Is it possible that the Family type in the Element Properties is set to "Sloped Glazing?"
Wed, Nov 16, 2005 at 1:36:52 PM | RE: transparent roof
swarch
attached is the roof plan. alll other drawings show correctly and i'm in shaded with edges. thoughts?
Wed, Nov 16, 2005 at 1:41:59 PM | RE: transparent roof
swarch
ok...so the .bmp didn't load, here's a jpg file.
Wed, Nov 16, 2005 at 3:22:48 PM | RE: transparent roof
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
That is normal for transparency of objects. Only 3D views show trasparency in objects. It is definitely to do with the material thats been applied to the roof or painted onto it...
Wed, Nov 16, 2005 at 3:44:26 PM | RE: transparent roof
#13
swarch
not sure i understand. view is plan, the 3D views show opaque. material transparency is 0. initially the roof was solid in this view and i did not modify the roof type prior to this change. all roof types are now transparent (shingle, generic, metal) and all slopes and phases but initial roofs were solid. thanks for pondering!
Wed, Nov 16, 2005 at 4:08:02 PM | RE: transparent roof
#14
swarch
it appears to always be in wireframe mode even with the other view options selected....therefore it may not be a "roof" issue but a graphics style issue. what could cause that?
Wed, Nov 16, 2005 at 4:50:23 PM | RE: transparent roof
#15
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, don't know if i can help without looking at the file. It's one of those issues that requires interrogation of the model. Maybe send to Autodesk Support for them to have a look at?
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
Walls disappear in roof plan after attaching to roof.
Wed, May 30, 2012 at 11:36:02 PM
I'm surprised... thin roofs are transparent?
Thu, Oct 4, 2018 at 8:08:15 PM
Transparent Walls
Thu, Mar 3, 2016 at 9:42:55 PM
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:06 AM
Page generation time: 0.4942
