34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Can you Merge Walls?
Tue, Dec 14, 2010 at 9:20:53 AM | Can you Merge Walls?
structuresguy
I have a long run of walls that was once a single continuous wall.   At some point when trying to model columns in the wall, we split the wall into several sections.  We could not get the columns to display correctly, as they kept taking the hatch pattern from the masonry wall.  We now want to merge the wall segments back together to make one long wall again.  Is there a way to do this?  We can't find any way to make it work.
Tue, Dec 14, 2010 at 9:30:00 AM | Can you Merge Walls?
3.5 Stars: 395 Votes
Just drag one wall back a little then drag it back, it should join back into one wall.
Tue, Dec 14, 2010 at 9:32:03 AM | Can you Merge Walls?
gdoherty0102
3 Stars: 2 Votes
Oh ya, for some reason I forgot about that...thanks WWHub, been a while since using RAC.
Tue, Dec 14, 2010 at 10:29:48 AM | Can you Merge Walls?
structuresguy
The walls do not merge back into one physical wall.  They just clean up to appear like one wall.  Is there a way to make them physically merge back into one wall?
Thanks.
Tue, Dec 14, 2010 at 10:35:28 AM | Can you Merge Walls?
Mine merged back into one wall.  Pick anywhere and entire wall is highlighted.  Did you pull it away,  stop then repick it and pull it back?
Tue, Dec 14, 2010 at 10:40:27 AM | Can you Merge Walls?
structuresguy
Thanks guys.  I figured it out.  I had edited the wall profiles of each section.  Once I did this, they would no longer join back together.  Once I reset the profiles, they merged back together.
Tue, Dec 14, 2010 at 10:42:00 AM | Can you Merge Walls?
structuresguy
None of this would ever have happened if they just made it so that structural columns inserted into a wall took precendent, and showed the hatch pattern of the column, not the wall.  So instead of being able to use columns for the concrete pillasters I have in a masonry wall, I need to use concrete walls, so that they show concrete hatch.  Very frustrating.  I don't understand why Revit has never fixed this problem.  It existed back in 2008, and it is still a problem in 2011.
Tue, Dec 14, 2010 at 10:47:52 AM | Can you Merge Walls?
If you used structural columns, they do not assume the wall material - only architectural columns assume wall finish.
Tue, Dec 14, 2010 at 7:22:31 PM | Can you Merge Walls?
structuresguy
ya, read what I said.  I USED STRUCTURAL COLUMNS!
Tue, Dec 14, 2010 at 7:24:53 PM | Can you Merge Walls?
structuresguy
It has never worked for us.  We have used Revit structure since version 2008, and structural concrete columns have always taken on the hatch of masonry walls that they are inserted into.  We have had to come up with all kinds of workarounds.  And I repeat, we are using structural columns, not architectural columns.
Tue, Feb 19, 2013 at 6:58:31 AM | Can you Merge Walls?
#11
Redg
Hello everyone
Im having problem with the door and i couldn see half of it. i think it s because i couldnt join that 2 walls...
Please help me...
/sorry about my english/
Tue, Feb 19, 2013 at 7:27:07 AM | Can you Merge Walls?
#12
Join the lower wall to the upper wall and the door will cut it.
Tue, Feb 19, 2013 at 8:45:02 AM | Can you Merge Walls?
#13
Redg
Im a begginer in revit.
I think join command is not working for some reason, and attach to the top also.
Tue, Feb 19, 2013 at 9:06:30 AM | Can you Merge Walls?
#14
Copy the file, delete everything except those two walls and the door.  Purge all then uploade.  Include which issue of Revit.
Tue, Feb 19, 2013 at 9:16:42 AM | Can you Merge Walls?
#15
Redg
im at home now. will try tommorrow...
thank you for your reply WWHub
Walls- merge regions
Sun, Feb 29, 2004 at 4:04:10 PM
merge or combine mesh
Mon, Jul 24, 2017 at 6:44:54 AM
merge or replace materials
Wed, Apr 26, 2017 at 8:03:10 AM
How to place a camera to merge a picture with the building model?
Fri, Nov 4, 2005 at 10:45:56 AM
Draw order furniture/walls
Thu, Mar 30, 2017 at 6:51:28 AM
Page generation time: 0.5981
