67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Keynotes tunred to ?
Tue, Aug 31, 2010 at 5:09:00 PM | Keynotes tunred to ?
quinn
We recently upgraded one of our project from Revit 2010 to 2011 and once it was done some of our keynotes in our views turned to blank with a ? when you highlight them.  When we went to one of the keynotes properties it still shows the correct keynote number but it doesnt show in the view.
We tried to renew the path to the txt file - didnt work
We tried to use our backup text file to overide the original to see if out keynotes would find that file - didnt work
When we try to create a new keynote using the same number it shows up blank.
It seems like our project cannot find certain text in our keynote file.  Some keynotes appear right others dont and never will.
Anyone know what is going on the only thing i can equate this to is when you copy a keynote and paste it into a different view and it shows up with the question mark and its not assoiciated to anything.
Wed, Sep 1, 2010 at 6:58:56 AM | Keynotes tunred to ?
3.5 Stars: 401 Votes
Was this a key note or a material note, there is a difference?
Your key note file path is set in the project.  Open the project, goto the annotate tab, click on the down arrow on the "tag" bar, click on keynote settings, in the popup, click on browse, find your file, set the file path type and numbering method then close by clicking on OK.  (BTW - we always keep the project keynote file with the model file.  The office standard may change but this file needs to be controlled with the project.)
Wed, Sep 1, 2010 at 10:09:36 AM | Keynotes tunred to ?
quinn
Its not an issue of obtaining the path we know how to do that.  We have it set by user and the path is by sheet, relative and connected to our file which is in our central file folder where the central file is.  This is not our issue our issue is that some of our keynotes we placed already that had numbers associated to them do not show in the sheet they are blank with a ? but in the properties they are still assigned to the text note in the keynote text file they belong to.  Some how "some" of them are not showing in the sheet.
Wed, Sep 1, 2010 at 10:29:11 AM | Keynotes tunred to ?
I don't know what a "path by sheet is"... maybe you meant number by sheet?
In a project upgrade, it might be possible that some associations might get messed up.  Is this a keynote "user"?  If not, then add a new keynote - user - select your note and see if the number now shows.  This really sounds like the assigned keynote did not get converted.  If that is the case, just change the question mark to the right number.
Wed, Sep 1, 2010 at 10:35:29 AM | Keynotes tunred to ?
quinn
Yes number by sheet.
The keynotes are made user. If we try to create a new keynote and select one of the notes that is associated to one of the blank notes the new keynote turns up ? as well.
Wed, Sep 1, 2010 at 10:43:55 AM | Keynotes tunred to ?
I don't understand - you wrote  "....If we try to create a new keynote and select one of the notes that is associated to one of the blank notes the new keynote turns up ? as well....  You mean place a new keynote - not create?
" ...as well"?  So you are saying it now works and both keynotes are there?
Wed, Sep 1, 2010 at 10:49:36 AM | Keynotes tunred to ?
quinn
How do we manually change the ? mark to the number? In the properties the correct number is still already assigned to the keynote and even if we go through properties reselect that number in the text file its still wont show it in the tag its still remains as ?.
Wed, Sep 1, 2010 at 10:52:16 AM | Keynotes tunred to ?
quinn
This is not easy to explain.
Some keynote tags do not show the number they just show up ? in the tag.
If we create a new keynote and pick the same keynote number in the text file of one thats corrupted, that keynote tag shows up ? as well.
Wed, Sep 1, 2010 at 10:53:10 AM | Keynotes tunred to ?
quinn - we are not communicating easily here....please pop into the chatroom for a few minutes
Wed, Sep 1, 2010 at 11:20:21 AM | Keynotes tunred to ?
quinn
We tried editing the keynote text file in notepad for keynote #10 and saved it. Repathed to it again and still it came up ?.  I think the only way we can fix the keynotes is to make a new keynote in the text file that is a new number as well, #10 seems to be lost.
Edited on: Wed, Sep 1, 2010 at 12:26:46 PM
Tue, Aug 14, 2012 at 11:15:04 AM | Keynotes tunred to ?
#11
Apexlion
Keynotes close to my match line show up this way with the ?.  Tag them far away from the match line then move the tag where it needs to be.
Any other solutions?
Tue, Aug 14, 2012 at 12:23:59 PM | Keynotes tunred to ?
#12
I have seen keynotes and material notes loose their host.  Typically, you can just tweak their pointer and they refind what they were pointing to.
Tue, Aug 14, 2012 at 1:00:58 PM | Keynotes tunred to ?
#13
Apexlion
It actually knows the host as the custom note does still show and in the legend it is numbered correctly but the actual
keynote bubble is blank. weird
Tue, Aug 14, 2012 at 1:30:09 PM | Keynotes tunred to ?
#14
You are using numbered keynotes with a keynote legend - correct?  So your legend has the correct keynote text for that number.  << See - that doesn't mean anything.
Delete the ? keynote - I bet the text is still there because there is something else with that number.  Add a new keynote and if it is an associate element keynote, the keynote will no longer be a ?.  As I said - it got lost.
Tue, Aug 14, 2012 at 1:38:51 PM | Keynotes tunred to ?
#15
Apexlion
None of what you say works. In the keynote legend it shows note 4 (auto-numbered by sheet) with the note.  when I look at the associated bubble it is blank, When I click the bubble I see the ? and in the properties it has the correct note.
If I keynote the element but move the bubble away from the match line (plan split into two parts) and place the bubble
 the number shows up then I move it back into place. Weird
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend?
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management
Mon, May 11, 2009 at 7:01:29 AM
Page generation time: 0.2289
