89 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> STAIR ARROW AND TEXT NOT SHOWN
Mon, Mar 15, 2004 at 6:35:39 PM | STAIR ARROW AND TEXT NOT SHOWN
TM
Does anyone know why the stair (and ramps) arrow and text sometimes does not show? I've checked in the stair/ramp properties and the, show text- up label - up arrow are all ticked. It's driving me nuts.
Fri, Sep 12, 2008 at 11:01:09 AM | STAIR ARROW AND TEXT NOT SHOWN
dugzxf
Did you ever find an answer?  I am having the same problem.
Thanks
Fri, Sep 12, 2008 at 2:17:56 PM | STAIR ARROW AND TEXT NOT SHOWN
JRMello
The arrow will only show up if that blue line is present in the stair sketch. As far as I know the only way to get it in there is to use the Run tool and then try copying and pasting the line where you need it, but it's really finicky and can change your stair in some annoying ways.
Sat, Sep 13, 2008 at 1:17:45 AM | STAIR ARROW AND TEXT NOT SHOWN
chiragpklg
4 Stars: 11 Votes
just check for the model Categories in Visibility/Graphics Override from View properties & check whether the Up arrow & text ption is checked or uncheked.
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Sat, Sep 13, 2008 at 4:56:42 AM | STAIR ARROW AND TEXT NOT SHOWN
4 Stars: 203 Votes
hi, JRMELLO has right, only if you create your stairs with run appears the UP or DOWN ARROW, you can create that arrow with "Drafting-Detail Lines"...
Sun, Sep 14, 2008 at 7:38:59 PM | STAIR ARROW AND TEXT NOT SHOWN
vicozzio
Oooo.. I see... Umm.. I usually go to element properties of stairs, and I will have these options under graphics, have you give check mark to them? Attached is the element properties...
Mon, Sep 15, 2008 at 1:30:29 PM | STAIR ARROW AND TEXT NOT SHOWN
4 Stars: 203 Votes
Yes, VICO, try to do a stair like this, (NO RUN) and check ON those box in properties, you will see....
Mon, Apr 20, 2009 at 7:12:34 AM | STAIR ARROW AND TEXT NOT SHOWN
jarosa
jarosa Avatar
4 Stars: 5 Votes
Had a similar problem and discovered that the view range has to be set to below stair also.
Mon, Mar 22, 2010 at 9:17:38 AM | STAIR ARROW AND TEXT NOT SHOWN
Dafpfy
3.5 Stars: 11 Votes
well i think the auto up arrow option in revit s$cks,
i tried everything posted here, and i have to go back to just drawing it with line's,
it just doesnt work and a waste of time to try and get it to work,
is it me or do you guys also have trouble getting this to work all of the time?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Tue, Sep 13, 2011 at 11:08:10 AM | STAIR ARROW AND TEXT NOT SHOWN
seti
I agree, there is no way to make the arrow visible if you draw the stair from scratch.
I think the best way to do go around this problem is to create a well designed detail component to place the arrow in the way its needed.
Saludos!
Thu, Oct 6, 2011 at 4:12:49 AM | STAIR ARROW AND TEXT NOT SHOWN
#11
markrummings
When creating a stair by boundary I also found the arrow not visible (but checked in the stair properties).  The easiest way round this is to draw an arrow using annotation lines then make a group out of it to copy to other levels.  Not the ideal situation but it works!
Thu, Oct 6, 2011 at 4:38:04 AM | STAIR ARROW AND TEXT NOT SHOWN
#12
Dafpfy
3.5 Stars: 11 Votes
lol i was in a good mood that day ^^
The group idea sounds interesting,
tnx
peace is the path."
Mahatma Gandhi.
Wed, Nov 14, 2012 at 10:31:32 AM | STAIR ARROW AND TEXT NOT SHOWN
Thread Post Kudo! Thread Post Kudo! #13
tdalias
5 Stars: 2 Votes
ANNOTATE--->STAIR PATH
ALL THE WAY ON THE RIGHT
OR DO CREATE SIMILAR
Tue, Apr 2, 2013 at 4:24:16 AM | tdalias
#14
cadboi08
Quoting tdalias from 2012-11-14 10:31:32
Perfect! Thank you!
Check out RevitTube for Awesome Revit Videos Daily - https://www.youtube.com/channel/UCl-rjEtxDTE0DOrtqOV8aKw
Tue, Apr 2, 2013 at 4:59:16 AM | tdalias
#15
vicozzio
Is this new feature in Revit Architecture 2013? I do not see any stair path under annotate tab in the ribbon (I'm using RAC 2012)..
Stair Path question
Wed, May 6, 2015 at 9:41:18 AM
Stair Arrow visible only in one view?
Thu, Oct 11, 2012 at 2:19:25 PM
stair arrow showing incomplete
Wed, Sep 12, 2012 at 1:43:21 PM
2013 stair path symbol for component stairs displays differently
Thu, Feb 6, 2014 at 3:03:50 PM
Rotating Family Text
Wed, May 7, 2014 at 5:04:06 PM
Page generation time: 0.7439
