117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> LOADING COMPONENT
Wed, Aug 24, 2005 at 5:07:34 PM | LOADING COMPONENT
jdesign
Hi guys, I have problem with loading component into my work. Every time I try to load a new component, the previous component is loaded instead of the new one even though I follow all the right steps to load it. Can I have input from you guys please. Thanks. Post edited on 2005-08-24 17:08:01
Wed, Aug 24, 2005 at 5:53:18 PM | RE: LOADING COMPONENT
Thread Post Kudo! #2
Xane
Did you try load it from file menu/load family
Thu, May 31, 2007 at 8:52:58 AM | LOADING COMPONENT
CrystalNanney
I too am having this problem.  MANY components will not appear in the list no matter how I load them.    It's not a visibility issue, they just don't seem to make it into the project.  What am I doing wrong?
Thu, May 31, 2007 at 9:39:35 AM | LOADING COMPONENT
framerman
4 Stars: 13 Votes
When you load a family, it doesn't always default to this one. Sometimes you have to click the drop down arrow to find it. Also, if it is not a component type family, you won't find it under "component" for example a window, or a structural beam. Check the families category under settings while in the family editor.
Wed, Nov 26, 2008 at 5:13:26 PM | LOADING COMPONENT
ChadG
I am running into this same problem, i have tried all of your suggestions but can't seem to get the family to load. It's actually the Roof Slope Symbol that i downloaded from RevitCity and now that im trying to load it into my project it doesnt seem register in the project file. I tried it in a new Revit Project, tried every possible way of loading the family (file menu, component load etc...) but everytime after i choose the family i want to load and click "Open" it defaults back to the family that was loaded last.
I'm fairly new to Revit so there is a possibility that im missing something very elementary. Any help is greatly appreciated, thanks.
Wed, Mar 18, 2009 at 4:21:31 PM | LOADING COMPONENT
Thread Post Kudo! #6
fixybopixy
i am having this exact problem right now and i cant figure out why. when i try to load a component (regardless of whether I do it thru File >load from library>load family or basics tab>component>load) I select a file i want to load, the computer acts like its going to load it (i.e. on the bottom right hand corner of screen it has that status bar showing the % of time it takes to load it), but of course, the component isnt there once i have loaded it. nor is it on the drop down list of components.
 any idea why?
Wed, Mar 18, 2009 at 4:58:31 PM | LOADING COMPONENT
tim123
4 Stars: 19 Votes
What type of component is it?  If it's a symbol it will not show in the component drop down menu.
Wed, Mar 18, 2009 at 5:03:25 PM | LOADING COMPONENT
fixybopixy
i dont think its a symbol. its a truss in teh structural > steel > framing folder in the imperial library, like a k series or LH series truss. none of them load.
Thu, Mar 19, 2009 at 12:46:28 AM | LOADING COMPONENT
RevitComponents
RevitComponents Avatar
4 Stars: 22 Votes
T O | DO
Placing structural families... __navigate to the "structural" design bar (window > design bars... > structural)
**Likely a "Brace', right?
Is your family there now?
Yes, structural familes are generally inserted via the "Structural" design bar__ya know... similar to Doors, which are inserted by selecting Doors (DR) or Windows (WN) or Tags (TG) or Symbols
(OH MYE)) Smile
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components]
Thu, Mar 19, 2009 at 2:15:08 PM | LOADING COMPONENT
fixybopixy
thank you. yes, when i go to the structural tab i can do the "brace" command and draw one of the trusses that I had previously loaded as a component. so that is great. however, when i do so, I draw the truss at angle for some reason, instead of having it flush with the level at which i drew it. so i tried modifying certain things in element properties, i.e. i made the reference level, the start attachment level reference, the start attachment elevation, end attachment level reference, the end attachment elevation all the same level (i.e. at 90') but still, the truss comes out angled, with one side at a lower elevation than the other side.
 how can i just make a flat truss is at the same elevation on both its sides?
Wed, Apr 8, 2009 at 12:18:28 AM | LOADING COMPONENT
fixybopixy
so i have another component, a horizontal louver system (.rfa file) that i downloaded from this web-site. for some reason, i cant load it into a project (.rvt file). not sure why.
 the louver system component is attached to this message for your reference.
Wed, Apr 8, 2009 at 12:45:07 PM | LOADING COMPONENT
4 Stars: 202 Votes
It's a "Curtain Wall", you can insert them when you create a curtain wall in your project and change the "curtain panels" in the properties of the curtain wall, but there are problems with this family....
Fri, Apr 10, 2009 at 11:38:26 AM | LOADING COMPONENT
#13
fixybopixy
typhoon, can u explain to me in more detail what u mean exactly? how exactly do i insert these screens (rfa files) into my curtain wall system (rvt files). it doesnt work when i do file > load from library > load family, nor can i copy and paste between family and project (obviously).
 i assume i am supposed to select one curtain panel (from the curtain wall system that i drew myself) and somehow replace it  with the screen, but i cant figure out how to replace one with the other.
 for your reference, i am attaching both files to this post
Fri, Apr 10, 2009 at 11:41:51 AM | LOADING COMPONENT
#14
4 Stars: 202 Votes
Can you wait for a video????
Fri, Apr 10, 2009 at 11:42:27 AM | LOADING COMPONENT
#15
fixybopixy
second file attached to this one, i accidentally didnt attach it to my previous post
problems loading detail components
Mon, Jan 29, 2007 at 3:54:19 PM
Adding Trusses into Revit Project
Tue, Sep 20, 2005 at 3:36:49 PM
Revit 2012 having trouble loading profile family for wall sweep
Sat, Jun 11, 2011 at 3:20:43 PM
11
loading family
Mon, Apr 22, 2013 at 4:40:20 AM
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:16 PM
Page generation time: 0.5978
