51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Surface pattern move/align/adjust problems
Mon, Aug 24, 2009 at 3:45:38 AM | Surface pattern move/align/adjust problems
RevitRainman
I am trying to align the surface patterns of various wall components (in revit 2010), however some elements refuse to allow me to move the surface pattern.
I can't seem to work out why as it seems to be  random as to what it will apply to.
The surface pattern is a model pattern, of simple horizontal lines.
The main problem seems to be ends of walls, where i get an error telling me the element cannot be moved (I am not trying to move the element, only the surface pattern line). Another problem is with hosted wall elements using the same brick pattern, moving the surface pattern lines moves the whole element instead of just the pattern...
anyone else experienced similar?? Anyone know how to resolve this?
Mon, Sep 28, 2009 at 3:44:15 PM | Surface pattern move/align/adjust problems
cholden
cholden Avatar
I have had a similar problem with a brick fill pattern on the end of a wall where I have indicated that the material is to "wrap" the end. It won't allow me to align the fill pattern so now my coursing looks off Sad
No solutions as of yet though......
Tue, Sep 29, 2009 at 7:46:56 PM | Surface pattern move/align/adjust problems
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
wow i havent really had any of these problems. all i know is make sure your patterns are model patterns. but i think yall already knew that.
please let me know if you find a soulution that is weird.
Edited on: Tue, Sep 29, 2009 at 7:49:27 PM
J. Allen Ball
Revit Architecture 2010 Certified Professional
Fri, Jun 11, 2010 at 12:22:02 PM | Surface pattern move/align/adjust problems
jimij
Okay I too had this problem and found a workaround I thought I'd share... What worked for me was splitting the face, in my case I drew my split face's edges 1/32" away from the real edge of the face, not noticeable in plans, then re painted the face with the material and then I was able to move the surface pattern around. Weird scenario, can't explain it, but there's your fix I guess for now.
Tue, Apr 24, 2012 at 1:22:08 PM | Surface pattern move/align/adjust problems
bhumphrey
Did anybody find a solution to this problem? I have this all the time lateley, with painted surfaces, or a material applied parametrically to a material in a family.
For example, I have a wood panel family that is flexibly dimensioned. Sometimes it has a pattern on it, other times not. The surface within the family is assigned a material instance parameter which I can then control on an element by element basis in the model. If I then try to move the pattern, or align it, the whole object/element moves rather than moving just the pattern.
Thu, Oct 29, 2015 at 11:11:21 AM | Surface pattern move/align/adjust problems
leggomyjeffko
Check to see if the pattern is a model pattern and not a detail pattern. You can't move detail patterns around.
Tue, Jun 7, 2016 at 1:07:05 PM | Surface pattern move/align/adjust problems
pilkington11
Anyone have a solution to this?
I'm making new families and the surface patterns are moving fine in the family (yes they are model patterns). When I load the family into a project, the surface patterns will not move. I've tried loading in the same material as well as making a new material in the project and still the surface patterns will not move for me.
I cannot paint it, I do not want to have 4 different materials for each frame and I do not want a quick work around.
Best practice solutions anyone??
See images to see the difference of material mapping between the family and the project.
Tue, Jun 7, 2016 at 1:53:07 PM | Surface pattern move/align/adjust problems
3.5 Stars: 391 Votes
Sorry - this is one of those items that needs to be fixed.
Although I haven't tried it, you might try using types in the family with the adjustment made there.
Tue, Jun 7, 2016 at 4:31:16 PM | Surface pattern move/align/adjust problems
revitwizard1995
revitwizard1995 Avatar
4 Stars: 3 Votes
Have you tried using the split face tool on the areas where you can't get the pattern to apply? It should automatically align the pattern with the other patterns, as long as it is the exact same material. Modify- Geometry- Split Face. You could also use it to cover the areas that are messed up.
Wed, Jun 8, 2016 at 6:21:29 AM | Surface pattern move/align/adjust problems
pilkington11
It is a parametric family, not a wall. I cannot split face and paint (nor do I want to).
I want to move the surface pattern to move the x and y coordinates of the render map. Does any one know why it works in the family and not in the project?
Wed, Jun 8, 2016 at 10:51:19 AM | Surface pattern move/align/adjust problems
#11
marmiketin1
4.5 Stars: 10 Votes
Im curious if the positioning of the brick pattern is locked to that position in the project. If you copy the window and move it horizontally does the brick pattern change at all with its positioning. If it does it might be that the pattern is somehow locked globally within the project. No idea how but you might try modelling something else then applying that brick material and using that object to try and shift the pattern on the window (if you change the pattern alignment on another object it may shift it on the windows)
Wed, Jun 8, 2016 at 12:16:04 PM | Surface pattern move/align/adjust problems
#12
pilkington11
I applied the same material on the exterior wall and was able to move both the surface pattern and the render maping with it, it was a good shot though!
Wed, Jan 4, 2017 at 4:05:05 PM | Surface pattern move/align/adjust problems
#13
kwinchell0502
How does one make a model pattern as opposed to a drafting when revit wont let me select model- what am I missing?
Thu, Jan 5, 2017 at 7:12:01 AM | Surface pattern move/align/adjust problems
#14
From your HELP HERE:
Notice the type definition.
Fri, Feb 10, 2017 at 6:01:32 AM | Surface pattern move/align/adjust problems
#15
Crazygirlzizou5
Hope this helps.
So I have been having the same problem, aligning a tile pattern on the end on a wall.
Reading some of the responses above I tried the split face strategy, however I simply split the end face of the all to below my ceiling level since the wall would only be tiiled to that point anyways, and then VOILA!
I was able to align the wall tile pattern to my hart's content.
Surface pattern wont align
Sun, Nov 9, 2008 at 3:16:04 AM
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:20 AM
how to change the base line of a revit pattern without use align
Tue, Sep 6, 2011 at 5:03:50 AM
Surface pattern problems
Sat, Jul 23, 2011 at 8:29:46 PM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
Page generation time: 0.6923
