61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> gable roof help
Wed, Aug 19, 2009 at 11:13:09 AM | gable roof help
vinnygolfer
4.5 Stars: 4 Votes
could someone please help me understand how to make these fake gable ends look better. the Architect has a lot of them and as you can see when i create them, they extend through the real roof. i saw that somebody suggested using ref lines to cut the roof. i'm not really clear on how to do that.
any help you could give to point me in the right direction would be greatly appreciated. thank you
by the way this is in architectural 2010
Try to learn at least one new thing every day
Wed, Aug 19, 2009 at 11:20:10 AM | gable roof help
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
use roof by extrusion and select the face of the ref. roof as your plane to extend to. You might have to use cut/join geometry. That's what's on top of my head now but I could be wrong too. Let me know your progress.
 "If you tell the truth, you don't have to remember anything"
Wed, Aug 19, 2009 at 1:01:40 PM | gable roof help
4 Stars: 203 Votes
Did you try with the "Join/unjoin roof" tool?
Wed, Aug 19, 2009 at 1:07:54 PM | gable roof help
vinnygolfer
4.5 Stars: 4 Votes
yes that image was after i joined all of those roof sections together. i'm having troble using the roof by extrusion. any ideas?
Wed, Aug 19, 2009 at 1:09:21 PM | gable roof help
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Ya... join/unjoin roof is the correct way to do it just like Typhoon said. or you can also use slope arrow. Ignore my previous post...I was thinking CAD. lol
Wed, Aug 19, 2009 at 1:18:50 PM | gable roof help
vinnygolfer
4.5 Stars: 4 Votes
all the roof sections were done with the roof by footprint then joined. is there a better way. please enlighten me
Wed, Aug 19, 2009 at 1:29:21 PM | gable roof help
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
type in "gable roof" in Revit help... it will show you how to do it. HELP in Revit is one the very good resources for information if you get stuck in something - you should try it.
Wed, Aug 19, 2009 at 1:40:59 PM | gable roof help
4 Stars: 203 Votes
Can you wait for a video???
Wed, Aug 19, 2009 at 1:48:46 PM | gable roof help
vinnygolfer
4.5 Stars: 4 Votes
yes they have me working on something else the rest of the day anyway. i will be trying this again at home tonight.
i looked at the tutorial in revit help. the only thing that i might have problems with are the roof sections that are under other roof sections. like the one to the bottom right in the photo that i included.
Wed, Aug 19, 2009 at 2:06:46 PM | gable roof help
4 Stars: 203 Votes
Hi, see the video: http://www.megaupload.com/?d=6OH162FK
I change the Link to Megaupload, that's why i Edit the post...
Edited on: Sat, Aug 22, 2009 at 5:03:48 AM
Wed, Aug 19, 2009 at 3:05:44 PM | gable roof help
#11
vinnygolfer
4.5 Stars: 4 Votes
thank you for the video. however it still isn't working for me. i don't know if i have a setting wrong, because when i made the extruded roof following along with you, my roof looks different. here is a screenshot. and i still can't get it to join/unjoin. i even tried using the pull handles to make sure it was only on the south side of the building. still no luck.
Wed, Aug 19, 2009 at 4:57:44 PM | gable roof help
#12
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
I think I know the problem.... you joined all the roofs already... you might need to unjoined them and use the join/unjoin tool....once you do that, you can drag by handle one the "section" (the one going thru the roof) and drag it towers the "profile" (the V shaped) then.... select join/unjoin tool and select one segment of the "V" shape profile (make sure you select the segment you are going to attach to the main roof... then, select the main roof you going to attach to. That should work, I tried it myself. Note: Once you select the join/unjoin roof tool.... just follow the prompt on the lower left corner for instructions.
Wed, Aug 19, 2009 at 4:59:00 PM | gable roof help
#13
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
not "towers" I meant towards.
Wed, Aug 19, 2009 at 10:14:37 PM | gable roof help
#14
vinnygolfer
4.5 Stars: 4 Votes
thanks for all the help everyone. with the ideas that you gave me and the tutorial for 4 sided gable roof in revit, i was able to get it done.
i used roof by footprint as before. but instead of making a rectangle for the roof shape, i used a triagle. then instead of setting the sides as slope defining, i used slope arrows on the front edge, that used the 6/12 slope i needed. and the attached file shows the problem is now resolved.
Wed, Aug 19, 2009 at 10:55:41 PM | gable roof help
#15
vinnygolfer
4.5 Stars: 4 Votes
lets try this again
How to join 2 gable roof?
Mon, Sep 28, 2009 at 9:16:38 PM
Extending one gable roof into another
Wed, Jun 11, 2008 at 3:09:43 PM
Roof
Fri, Dec 30, 2005 at 8:11:34 AM
Extending roof into double gable
Fri, Oct 23, 2015 at 10:40:00 PM
"Dutch Gable" roof
Mon, Mar 31, 2008 at 1:35:55 PM
Page generation time: 2.4524
