66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Standing Seam Roof
Mon, May 11, 2009 at 2:13:27 PM | Standing Seam Roof
GRAKris
I need to render a standing seam roof in 2009.  What is the easiest way I can render this roof?
Mon, May 11, 2009 at 2:22:47 PM | Standing Seam Roof
If you can find an appropriate material that will give you the ribs - use that.  Otherwise, you may have to model the ribs.
Mon, May 11, 2009 at 5:02:21 PM | Standing Seam Roof
tim123
4 Stars: 19 Votes
There is a bump map in the library, see attached.  This works well for most situations, but for views that are close up I tend to model the ribs.  This can be done quite easily using curtain systems, or sloped glazing for a roof.
Tue, May 12, 2009 at 8:17:58 AM | Standing Seam Roof
GRAKris
Thanks for you help.  I actually went a different route.  I just copied the roof, place it 1" higher than my original roof and sized it to a seam width and placed it every 8" or so.  It worked great and modeled great.
Tue, May 12, 2009 at 9:28:10 AM | Standing Seam Roof
dhollyman1
  1. Put the basic initial roof on the house.. using whatever construction desired (2x12 or trusses with sheathing)
  2. copy that roof and turn it into "Glass Panel"
  3. Then lay the "Glass Panel" onto the roof that you copied.
  4. You can go into the glass panel and change materials so that it matched your desire
  5. Also, you can change the spacing/Size of the Glass Panels
  6. Tada! Standing Seam Metal Roof...
Good Luck! This works really well
Fri, Jul 17, 2009 at 8:08:50 AM | Standing Seam Roof
JHanby
3.5 Stars: 3 Votes
I have a semi circle canopy that needs to have a standng seam.  I used the extrustion method to make the roof.  How do I get the ribs to follow the curve of the roof instead of the direction of the extrusion?  Using RA2009.  I used the method of creating 2 roofs, one over the other with the top one being the sloped glazing, for my main hip roof.
Fri, Jul 17, 2009 at 8:21:19 AM | Standing Seam Roof
4 Stars: 203 Votes
Images of your roof please...
Fri, Jul 17, 2009 at 8:29:51 AM | Standing Seam Roof
JHanby
3.5 Stars: 3 Votes
Fri, Jul 17, 2009 at 9:06:12 AM | Standing Seam Roof
4 Stars: 203 Votes
Yeah use the "Sloped Glazing" system, i think it's the best option...
Fri, Jul 17, 2009 at 9:52:37 AM | Standing Seam Roof
JHanby
3.5 Stars: 3 Votes
how do i get the "ribs" to follow the curve and not the extrusion?
Fri, Jul 17, 2009 at 9:55:18 AM | Standing Seam Roof
#11
4 Stars: 203 Votes
??? like my image?? do it with the "Sloped Glazing" system....
Mon, Jul 20, 2009 at 6:17:05 AM | Standing Seam Roof
#12
JHanby
3.5 Stars: 3 Votes
THE ROOF IS SET TO "SLOPE GLAZING"!!!!!!!!!!!!!!!
Mon, Jul 20, 2009 at 7:02:36 AM | Standing Seam Roof
#13
coreed
coreed Avatar
4 Stars: 16 Votes
i think you have to add mullions now to simulate the standing metal seam?
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jul 20, 2009 at 8:19:50 AM | Standing Seam Roof
#14
4 Stars: 203 Votes
CREATE A NEW "PROFILE FAMILY" WITH THE SHAPE YOU WANT, LOAD INTO THE PROJECT, GO TO THE PROJECT BROWSER/FAMILIES AND EXPAND THE CURTAIN WALL MULLIONS, IN THE RECTANGULAR MULLION EXPAND AND DUPLICATE ONE OF THEM, CHANGE THE NAME AND ENTER IN THE PROPERTIES, CHANGE THE "PROFILE" BY THE NEW YOU JUST CREATE, PICK IN THE ROOF (SLOPED GLAZING) AND GO TO THE PROPERTIES, EDIT/NEW AND CHANGE THE LAYOUT BY THE NEW MULLION YOU JUST CREATE BEFORE, CHANGE THE PROPERTIES YOU NEED (FIXED DISTANCE, OFFSET....).
DONE....
Tue, Apr 21, 2020 at 8:58:10 PM | Standing Seam Roof
#15
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
I just created a Dynamo Script which Generate standing seams instantly.
watch my vid here
https://youtu.be/Jj8yrpywut4
Edited on: Tue, Apr 21, 2020 at 9:02:08 PM
want more?
You can get more tips at Enjoy Revit
Standing Seam on a barrel vault roof
Tue, Jul 23, 2013 at 9:06:23 AM
Standing Seam Roof
Wed, Jan 4, 2006 at 5:08:30 PM
Standing Seam Roofs
Fri, Mar 16, 2007 at 3:16:56 PM
Standing Seam Roof
Thu, Nov 14, 2013 at 3:49:44 PM
Standing Seam Problem
Sun, May 1, 2011 at 1:39:08 PM
Page generation time: 2.0082
