103 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how to dreate a double gable ended roof on a square structure????
Thu, Mar 12, 2009 at 2:15:05 PM | how to dreate a double gable ended roof on a square structure????
jnordby
I want to have a double gable ended roof structure on a sqaure structure??????  What is teheasiest way to achive it???
Thu, Mar 12, 2009 at 2:16:25 PM | how to dreate a double gable ended roof on a square structure????
4 Stars: 203 Votes
Images of what you want...
Thu, Mar 12, 2009 at 2:48:34 PM | how to dreate a double gable ended roof on a square structure????
jnordby
Like this but better.....
Thu, Mar 12, 2009 at 3:32:35 PM | how to dreate a double gable ended roof on a square structure????
4 Stars: 203 Votes
Like this???
Thu, Mar 12, 2009 at 3:41:02 PM | how to dreate a double gable ended roof on a square structure????
jnordby
YEs but all four sides look a like.....
Thu, Mar 12, 2009 at 3:50:07 PM | how to dreate a double gable ended roof on a square structure????
4 Stars: 203 Votes
" but all four sides look a like....." - What you mean???
Thu, Mar 12, 2009 at 4:16:57 PM | how to dreate a double gable ended roof on a square structure????
jnordby
OK HOW???
Thu, Mar 12, 2009 at 4:35:31 PM | how to dreate a double gable ended roof on a square structure????
4 Stars: 203 Votes
See the video: http://screencast.com/t/sO6awtHb1d
Thu, Mar 12, 2009 at 6:05:30 PM | how to dreate a double gable ended roof on a square structure????
jnordby
TY for the quick video. I did everything that you said but when it came time to finish the roof it gave me a error 1 message?????
Thu, Mar 12, 2009 at 6:19:01 PM | how to dreate a double gable ended roof on a square structure????
jnordby
says can't make footprint.....
Thu, Mar 12, 2009 at 6:25:48 PM | how to dreate a double gable ended roof on a square structure????
4 Stars: 203 Votes
Put a small value in the slope of every gables, if you put 30 use 15 then it works, finish the sketch, after this pick in the roof go to properties and change again the slope value to 25, 30, whatever. BTW, it's a square structure isn't????
Thu, Mar 12, 2009 at 7:39:19 PM | how to dreate a double gable ended roof on a square structure????
jnordby
I am using residential slopes not degree's???  I had 8/12 and then tried 3/12 and noting worked???? Yes it is square.
Fri, Mar 13, 2009 at 4:09:32 AM | how to dreate a double gable ended roof on a square structure????
#13
4 Stars: 203 Votes
Did you split the lines in the middles of them???? Are the Slope arrows with the same slope value???
Fri, Mar 13, 2009 at 10:58:59 AM | how to dreate a double gable ended roof on a square structure????
#14
jnordby
yes and yes   I tried over three to four times and always started from scratch......just how you showed in the clip.
Fri, Mar 13, 2009 at 11:14:45 AM | how to dreate a double gable ended roof on a square structure????
#15
4 Stars: 203 Votes
Wierd.... you are doing something wrong.... I do this later with the Units in "feets and Fractional inches"....
Extending roof into double gable
Fri, Oct 23, 2015 at 10:40:00 PM
another double pitch roof question!
Thu, Jun 14, 2007 at 10:42:51 AM
Gable End Fascia
Wed, May 23, 2007 at 5:45:51 AM
Gable vents Family?
Sat, Nov 27, 2004 at 12:36:47 AM
How to join 2 gable roof?
Mon, Sep 28, 2009 at 9:16:38 PM
Page generation time: 1.2880
