101 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Render Calculation Error?
Tue, Mar 10, 2009 at 10:44:14 AM | Render Calculation Error?
kripple51
I have a rather large building that I am trying to render. I have done a couple of drafts in the past and it worked fine, but now it doesn't. When I try to render now I get an error that says "unknown error during rendering calculations. The rendering operation will be canceled." Then the rendering proceeds but nothing shows up. I have tried exporting to Max but every time I get a fatal error that closes Revit. Can anyone tell me why this might be happening or what I can do to prevent it? I have tried breaking the rooms into smaller files, but that doesn't make a difference. I would really appreciate any help!
Thanks
Tue, Mar 10, 2009 at 11:54:46 AM | Render Calculation Error?
4 Stars: 204 Votes
Did you try to "Audit" the file????
Tue, Mar 10, 2009 at 12:16:34 PM | Render Calculation Error?
kripple51
I actual don't know how to audit it, but I did purge. I sent in an error report and CAD sent me back an update that I needed. Luckily after hours of trying to figure it out on my own, this fixed it. Thanks for your response.
Tue, Mar 10, 2009 at 1:38:22 PM | Render Calculation Error?
4 Stars: 204 Votes
FYI... Audit
Thu, Mar 12, 2009 at 1:26:30 PM | Render Calculation Error?
kripple51
Ok, so I have audited and purged. I have updated and I am still having issues. The calculation error has come back on some of my renderings. On the ones that make it through the calculation error I get a runtime error. I have tried spliting up my building into separate files and deleted what you cant see in that particular view. This usually fixes the calculation error, but then I get a runtime error. I have tried exporting into Max, but not everything goes over smoothly, plus I have an exterior rendering with trees. Am I just out of luck or is there someone out there who has had this issue and been able to solve it? I have tried to change to a 3GB too, but that didn't seem to change anything. I have also upped the amount of virtual memory that my comp allows. I still have a little time before the due date, but I would rather not be scrambling. Please Help!!!!!!!
 PS. I am on Revit 2009
Edited on: Thu, Mar 12, 2009 at 1:27:27 PM
Thu, Mar 12, 2009 at 1:33:52 PM | Render Calculation Error?
kripple51
I just read another thread that "Typhoon" started with the same error. I am running on XP. Do I seriously need to get Vista in order to get past this error or is there another way?
Thu, Mar 12, 2009 at 1:34:57 PM | Render Calculation Error?
4 Stars: 204 Votes
Specifications of your machine please (Ram, processor, O.S., etc)???? did you have the last Web Update 3 ???
Sat, Mar 14, 2009 at 5:28:55 PM | Render Calculation Error?
kripple51
ok well i have 3G of ram and I am running on Windows XP. I am using an HP Pavillion and I have an Intel Core Duo Processor. I do have the latest update and I have tried downloading 1 & 2, but i get an error saying that it cant find the specified program. thank you so much for your time.
Sat, Mar 14, 2009 at 7:06:42 PM | Render Calculation Error?
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
why anyone wouldn't be running vista is beyond me..
it makes no sense to not use it..
Sat, Mar 14, 2009 at 11:41:31 PM | Render Calculation Error?
kripple51
I bought my comp right before vista came out. Why would I fix something that isn't broken. Not to mention the fact that when vista first came out it caused a lot of problems with CAD.
Sun, Mar 15, 2009 at 1:00:44 AM | Render Calculation Error?
#11
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
everything causes problems when it first comes out..
all processors are 64 bit vista ready unless you have an
old pentium dog..
Sun, Mar 15, 2009 at 9:12:09 AM | Render Calculation Error?
#12
4 Stars: 204 Votes
I have a Dual core 2 duo 2.4, 8GB Ram and use the VISTA 64, no problem at all, until now...
Sun, Mar 15, 2009 at 8:54:21 PM | Render Calculation Error?
#13
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
sorry to hear that typhoon- but i think your wife
told you not to mess with that girl in the first place..
yup..
Mon, Mar 16, 2009 at 4:13:44 AM | Render Calculation Error?
#14
4 Stars: 204 Votes
What?
Mon, Mar 16, 2009 at 5:34:05 AM | Render Calculation Error?
#15
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
well if you had no problems until now- what else could it be..
Stair Material Takeoffs - Volume Calculation Error when Painting
Tue, Dec 10, 2013 at 7:45:46 AM
Error: Revit was unable to render the view due to an unknown error.
Mon, Apr 28, 2014 at 3:32:17 AM
Render Error - "Unknown Error during Rendering Calculations"
Fri, May 1, 2009 at 1:52:23 PM
help: why do I get a server error when I try to render revit in iCloud??
Tue, May 20, 2014 at 12:58:46 PM
Error in RAC 2009-RENDER
Thu, May 22, 2008 at 4:28:46 AM
Page generation time: 0.4140
