Forums >> Revit Building >> Technical Support >> Truss roof
72 Posts No Rating |
Hi all . help me fix truss !
Hi, pick on the element and pick in "Make Continuous", see the image attached....
![4 Stars: 1 Votes](/images/stars_4.gif) |
TYPHOON How did you create that tile? Is each one individual? and doingt a whole roof like that would take forever to render or bog the file down, correct?
No, this tiles ara a family like you can see in the image, the whole model you can see now in the image attached and Yes, increase the file size but this ALL 3D, when you create the section views you don't need to create 2D details for this because it's all done.... The render it's OK, my machine works good with this...
Edited on: Wed, Dec 10, 2008 at 11:08:28 AM
that makes sense, not to be a pain or anything but do you know of a tutorial or something to help show me how to actually apply that to a regular roof? How you attach it to the ridge on the slope and the main roof. I have done somethine similar with a metal roof. I created a profile, then did a mass, profile sweep and applied it to the angle of the roof and then copied it a million times to cover the width of the roof. That really put a hurting on my computer but I didnt know any other way to do it.
"I have done somethine similar with a metal roof. I created a profile, then did a mass, profile sweep and applied it to the angle of the roof and then copied it a million times to cover the width of the roof. That really put a hurting on my computer but I didnt know any other way to do it." - LOL... First see this: 1º video: http://screencast.com/t/trJwHTYMmH 2º Video: http://screencast.com/t/QhyBfWqsO This two videos explain how you can create in 3d the whole roof, NOT the RIDGES, and the Corners but the roof it self. The ridges, the corners and the edges i put in attached ....
Edited on: Wed, Dec 10, 2008 at 11:40:17 AM
Thank you for your help. I tried it out on a hip roof with four sides and i kind of got it to work. It is a little more difficult getting the joints to work with the slope and stuff.
@ Typhoon I created roof same picture . I have a question : In a sloped glazing , how many layer of truss i can creat on . Another question : In sloped glazing I creat two layer of truss but why do they intersection ( i want layer truss on another layer ) . Have you video clip for tile roof ? I would like to download : http://screencast.com/t/QhyBfWqsO and http://screencast.com/t/trJwHTYMmH Please give links . Thanks so much I use Rac 2009 unit meter
Edited on: Wed, Dec 10, 2008 at 1:18:32 PM
THE WHOLE SLOPED GLAZING IS NEW TO ME. EVERYTHING LOOKS GOOD IN THAT PICTURE
Trandung, i'm downloading to put in MEGAUPLOAD, when it's ready i put here the links, about the rest i gonna make some videos, ok? ROBERT? did you see the videos?, did you understand how you can create profiles and use to create the 3D roof???? Trandung this is the videos you ask: 1ºvideo: http://www.megaupload.com/pt/?d=4O2E8XPO 2º video: http://www.megaupload.com/pt/?d=RRMNJCIS
Edited on: Wed, Dec 10, 2008 at 1:59:58 PM
YES THANK YOU FOR YOUR HELP. HERE IS MY PROBLEM THOUGH
Hi, don't forget first to DUPLICATE the Roof and give them different name, see this: 1º video: http://www.megaupload.com/pt/?d=08SZCTL6 2º video: http://www.megaupload.com/pt/?d=7XVH0SJ6 3º video: http://www.megaupload.com/pt/?d=D6IGH4MK
I HAVE TO DOWNLOAD STUFF TO LOOK AT IT
@Typhoon What programsed see *.swf . FLV player can use ? Sorry, I use IE for openning *.swf . Thanks
Edited on: Wed, Dec 10, 2008 at 7:41:49 PM
I creat wood beam finish . But slopped galzing for tile roof i can not do . The file 49629 cumeira2.rfa (profile for tile roof ?). I saw the same your video but i can not change mullion !!!. Help me . Thanks
Can't see Truss under roof |
Tue, Feb 16, 2010 at 4:29:05 PM
Hip roof Truss |
Fri, Nov 10, 2006 at 10:18:49 AM
roof truss install |
Tue, Feb 10, 2009 at 9:00:56 PM
12
Revit roof... truss vs. rafter |
Wed, Dec 18, 2013 at 11:26:22 AM
Truss overhang help |
Wed, May 23, 2012 at 8:32:23 AM
Members: | 2022428 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
