101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Trees can't be rendered?
Sat, Aug 23, 2008 at 11:32:10 PM | Trees can't be rendered?
alc112
Hi!
I'm Using RAC 09
I don't know why but the treesI have in my project are not being rendered (they are not shwoing up in the final redered image although I'd placed them in the project)
In RAC08 I could rander trees
What can I do?
Thanks
Sun, Aug 24, 2008 at 12:37:09 PM | Trees can't be rendered?
4 Stars: 201 Votes
Those trees you try to render it's a OLD project (i.e. RAC 200Shadey? or it's a new project with TREES from RAC 2009?
Sun, Aug 24, 2008 at 1:54:19 PM | Trees can't be rendered?
alc112
I inserted the trees in RAC 09 form its own family library.
Sun, Aug 24, 2008 at 2:02:59 PM | Trees can't be rendered?
4 Stars: 201 Votes
Hi ALC, can you put the image AFTER render to see the trees and see how they looks like?
Sun, Aug 24, 2008 at 2:14:55 PM | Trees can't be rendered?
alc112
Here they are
Sun, Aug 24, 2008 at 2:29:20 PM | Trees can't be rendered?
4 Stars: 201 Votes
Hi ALC, i think you insert a OLD tree from 2008, so delete them and insert a RPC like in the images attached...
Sun, Aug 24, 2008 at 3:10:04 PM | Trees can't be rendered?
alc112
Thank you very much, Typhoon!
Sun, Aug 24, 2008 at 3:11:36 PM | Trees can't be rendered?
4 Stars: 201 Votes
You Welcome ALC, como te va? ya has acabado el curso?
Edited on: Sun, Aug 24, 2008 at 3:11:49 PM
Sun, Aug 24, 2008 at 7:53:52 PM | Trees can't be rendered?
alc112
Hola!
Te refiere alcurso de video?
SI! me ayudó muchisimo.
Now I have another problem: the sky is not rendering. I just got a grey generic material-like color.
Mon, Aug 25, 2008 at 3:14:44 AM | Trees can't be rendered?
4 Stars: 201 Votes
You muts see the parameters in the SUN settings, go to settings or SU and check the date and hour, you probably has the hour near the sunset.... put the hour in i.e.= 15:00PM, 16:00PM and check...
Mon, Aug 25, 2008 at 9:31:35 AM | Trees can't be rendered?
#11
alc112
Nope. I set at Summer 15 pm Buenos Aires
Can oyu do me a favour?
Can you make a render where the only visible 2thing" is just the sky?
So I can use it as backgound in photoshop
thank you!
Mon, Aug 25, 2008 at 9:55:01 AM | Trees can't be rendered?
#12
4 Stars: 201 Votes
Hi man, i can't do that because right now i don't have here the 2009, i'm not at my office, but, tell me something, by your last image, i'm not sure but is THAT a CAMERA VIEW? or is a normal 3D VIEW?
Mon, Aug 25, 2008 at 1:19:08 PM | Trees can't be rendered?
#13
4 Stars: 201 Votes
Hi ALC, i just send you a Email with 4 (four) Skies rendering in 2009 - BEST quality.
Tue, Aug 26, 2008 at 8:42:35 AM | Trees can't be rendered?
#14
alc112
Thanks A LOT!
I'll send you a image of my render
I set the highest settings and the render took 14 hours to finish!
Tue, Aug 26, 2008 at 9:12:35 AM | Trees can't be rendered?
#15
4 Stars: 201 Votes
Hi alc, you welcome,  i just see the image of render in the email, it's good, i put some comments (ahahah) there... b«y the way, try other view but with the camera DOWN to UP, in the properties of the camera go to "Eye and Target elevation" and change the values EYE(Camera)= 1.75m > TARGET= 10m, change the values until you have a good view then RENDER.... bye....
Rendering Trees/Searching
Fri, Jun 17, 2011 at 2:49:30 PM
Australian Plants
Wed, Dec 3, 2008 at 8:02:14 PM
80' trees for Revit Architecture 2008
Wed, May 16, 2007 at 2:53:15 PM
2D trees - Elevations
Wed, Oct 10, 2012 at 4:00:17 AM
Rendering RPC's trees on site plan view!
Mon, May 7, 2012 at 7:33:47 PM
Page generation time: 0.6954
