59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stair railing at the interior corner of a landing
Wed, Aug 6, 2008 at 2:43:59 PM | Stair railing at the interior corner of a landing
aaronkennedy
I am having a problem with a stair railing.  I have included a screen image of it.  The railing splits at the landing.  Any advice?
Wed, Aug 6, 2008 at 3:03:10 PM | Stair railing at the interior corner of a landing
4 Stars: 201 Votes
Hi, where is the image? did you create two boundaries lines (one in the steps (risers) and other in landing)?
Edited on: Wed, Aug 6, 2008 at 3:46:47 PM
Wed, Aug 6, 2008 at 4:00:17 PM | Stair railing at the interior corner of a landing
aaronkennedy
sorry here it is
Wed, Aug 6, 2008 at 4:13:34 PM | Stair railing at the interior corner of a landing
4 Stars: 201 Votes
Hi, delete the left rail and do another and see if the parameters of the rail (duplicate with another name) see the images attached: is what you need?
Wed, Aug 6, 2008 at 4:30:06 PM | Stair railing at the interior corner of a landing
broncos4life
4 Stars: 10 Votes
This is not a Revit thing as this is how it actually has to be  made.  Revit keeps your railing at the height you set above the nosing of the stairs...this issue is an architectural issue not Revit.  To get this to clean up nicely what I would suggest is to add an additional 11" (or what ever your tread size is) to the landing right below top portion of the stairs.  This will alow the railing to get to the same elevation as the railing that starts on the lower section of the stairs.  Let me know if this is clear...if not I can post a picture or something.
HTH
Grant Doherty
Wed, Aug 6, 2008 at 4:34:06 PM | Stair railing at the interior corner of a landing
4 Stars: 201 Votes
Bronco, can you put some images of what do you tell because you work inches (feet and fractional inches) and i work in meters, so my confusion...
Wed, Aug 6, 2008 at 4:42:22 PM | Stair railing at the interior corner of a landing
broncos4life
4 Stars: 10 Votes
Ok, attached is a picture of what I am talking about.  See how my landing extends the same distance as my tread?  This allows the raling to get back down to the same level as where the railing that goes down the lower portion of the stairs starts.
Wed, Aug 6, 2008 at 4:46:54 PM | Stair railing at the interior corner of a landing
4 Stars: 201 Votes
but in this case (your image) your tread or riser, don't start like the same way in my image (the first image i post in plan)
Wed, Aug 6, 2008 at 5:00:11 PM | Stair railing at the interior corner of a landing
broncos4life
4 Stars: 10 Votes
The way you drew it doesnt give the railing comming down a chance to get to the same height as the railing on the landing.
Wed, Aug 6, 2008 at 5:07:28 PM | Stair railing at the interior corner of a landing
4 Stars: 201 Votes
yeah, i know that, but he don't put any image of stair in plan, so to create a railling like he post in 3d image it's like that, the riser start in the corner of the other, what you do is create a "Extra" part of landing and then begin the riser, i don't know if it's what he want but like the 3d images he post i suppose that is, AARONK, can you put the image in plan of that stairs?
Edited on: Wed, Aug 6, 2008 at 5:08:02 PM
Wed, Aug 6, 2008 at 5:12:21 PM | Stair railing at the interior corner of a landing
lunchtrayrider
3.5 Stars: 7 Votes
Yea a good rule of thumb I've heard from people is when you have a landing extend the landing half a tread before the landing and half a tread after. then the railings will be pretty close to lining up.
Wed, Aug 6, 2008 at 5:17:26 PM | Stair railing at the interior corner of a landing
4 Stars: 201 Votes
Yeah, but what hapend when you have (and there aren't so few situations) like this:
Wed, Aug 6, 2008 at 5:28:55 PM | Stair railing at the interior corner of a landing
#13
broncos4life
4 Stars: 10 Votes
Revit will not put  in a vertical rail and that is exactly what those two instances, geometricly, have to have to get the two railings to connect.
Wed, Aug 6, 2008 at 5:35:51 PM | Stair railing at the interior corner of a landing
#14
4 Stars: 201 Votes
So, how do think is the best way to solve this situations (like in the images) i post? the right railing it's ok the problem is the left railing...
Wed, Aug 6, 2008 at 5:41:18 PM | Stair railing at the interior corner of a landing
#15
broncos4life
4 Stars: 10 Votes
If you have to have the treads go like you have so the railing needs a vertical piece i cant really say.  The only way to get this to show up correctly in 3D would be to model your railings in place by hand, this is VERY ardous though...I did this on one of my projects and it took me 3 days to get the railing to look perfect.  Probably wouldnt do it again.  I would just leave it looking wrong and detail it in elevation and plan to look correct.
stair railing transition at landing issue (2015)
Wed, Sep 16, 2015 at 9:29:50 AM
Stair-ramp-landing Problem
Mon, Mar 24, 2014 at 11:13:25 AM
Starting a Rail on the stair landing.
Thu, Dec 19, 2013 at 3:01:59 PM
Railings and Stairs
Fri, May 16, 2014 at 12:12:16 PM
how to connect railing corner?
Wed, Jan 26, 2011 at 9:26:03 AM
Page generation time: 0.4712
