42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Finish Profile at Stone Coping
Wed, Jul 23, 2008 at 7:27:45 PM | Finish Profile at Stone Coping
citroen
I added the cast stone coping via wall profile successfully after hours of trying to figure out how to do this.  I'm new to Revit but getting the hang of it day by day.  How do I get the ends of the coping to the correct profile?  I tried wall returns but it cuts the corners and exposes the cut area with a diagonal.
Wed, Jul 23, 2008 at 8:46:52 PM | Finish Profile at Stone Coping
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I can't really see the image well, but im guessing the look your going for can be acheived with a wall sweep rather than building the sweep into the structure. With a wall sweep you can change the sweep return.
Thu, Jul 24, 2008 at 4:40:03 AM | Finish Profile at Stone Coping
4 Stars: 201 Votes
Hi CITROEN, the image you post is not clarify, can you ZOOM to the zone in question so we can figure out what do you need?
Thu, Jul 24, 2008 at 5:28:42 PM | Finish Profile at Stone Coping
citroen
Here's a close up.  I'm pretty new to Revit so your advanced responses are not as straightforward to understand.
Thu, Jul 24, 2008 at 6:00:07 PM | Finish Profile at Stone Coping
lunchtrayrider
3.5 Stars: 7 Votes
does your wall have the exterior finish wrapping?
Thu, Jul 24, 2008 at 6:16:16 PM | Finish Profile at Stone Coping
citroen
Yes, but the coping at the end gets cut off.
Fri, Jul 25, 2008 at 5:12:10 AM | Finish Profile at Stone Coping
4 Stars: 201 Votes
That profile in the top of wall is what? extrusion, blend sweep, what?
Fri, Jul 25, 2008 at 2:34:11 PM | Finish Profile at Stone Coping
citroen
It's a wall sweep with a custom profile as noted above.
Sun, Jul 27, 2008 at 2:26:02 PM | Finish Profile at Stone Coping
alabaster2513
3.5 Stars: 25 Votes
That's a good place to build an in-place family. I would create the majority of the element with an extrusion then add the detailed area of the stone face with a sweep around the extrusion. Or else build it all with one single rectangular sweep.
 I am curious if you build your wrought iron railing there with just model lines?
Mon, Jul 28, 2008 at 12:09:20 PM | Finish Profile at Stone Coping
citroen
alabaster2513, thanks for your response.  I'm not sure I get what you said.  How do you create the coping as an extrusion?  Using what category?  Could you be more specific as to what you mean by building as one rectangular sweep?  I'm on a deadline so I would appreciate some help.  Or what other source can I look at for adding details to make the project more convincing.  I'm not sure the tutorials were all that helpful in this case.
I built the wrought iron railing with just model lines, yes.
Mon, Jul 28, 2008 at 1:31:25 PM | Finish Profile at Stone Coping
alabaster2513
3.5 Stars: 25 Votes
Here is just a quicky i did.
I created an in-place-family in the walls category. Extruded the main mass from the top of the wall, then i traced a path for the sweep around the extrusion.
Mon, Jul 28, 2008 at 1:49:50 PM | Finish Profile at Stone Coping
4 Stars: 201 Votes
Or you can create only one extrusion and after create a void around the extrusion...
Mon, Jul 28, 2008 at 7:39:44 PM | Finish Profile at Stone Coping
#13
citroen
Alabaster 2513,
Can you save that attachment as revit 2008?
 Typhoon,
 Your last comment...Can you describe step by step.  It's a little over my head.
Tue, Jul 29, 2008 at 3:48:03 AM | Finish Profile at Stone Coping
#14
4 Stars: 201 Votes
Hi CiTROEN, right now i dont have here my revit and JING to create you a Video to explain the process but, if you can wait , when i have the oportunity i create a video for you with the ALABASTER process and With extrusion and void sweep...
Tue, Jul 29, 2008 at 10:43:59 AM | Finish Profile at Stone Coping
#15
alabaster2513
3.5 Stars: 25 Votes
sequence as follows
1. basic/wall
2. pick plane/top of wall
3. modeling/create/wall
4. solid extrusion (to create the center mass)
5. solid sweep (sweep your profile around the extrusion)
6. join geometry (join the extrusion and the sweep to appear as one element)
Sloping wall capping
Sat, Oct 17, 2009 at 4:58:30 PM
Stone walls
Sat, Jan 12, 2013 at 5:40:42 AM
Problem creating coping
Fri, Aug 18, 2006 at 4:31:48 PM
Coping Profile
Tue, Aug 17, 2010 at 6:46:21 PM
Truss - coping frame members
Mon, Aug 16, 2010 at 5:51:35 AM
Page generation time: 2.5209
