69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Rendering in Revit 2009
Thu, Jul 3, 2008 at 1:33:39 AM | Rendering in Revit 2009
cpbc
3.5 Stars: 3 Votes
I wonder has anyone faced the same problem when they render the sky in Revit 2009? Since Revit 2009 does not allow you to place a background image, I am finding it diffcult to do a good sky for my rendering. Furthermore, my sky rendering stops at certain level (as attached). Wonder how to make the sky goes all the way down just as in Revit 2008?
 Rgds,
cpbc
Thu, Jul 3, 2008 at 2:01:04 AM | Rendering in Revit 2009
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
The sky in RA2009 is using Mental Ray to produce a physical sun and sky dependant on time, date and location.  As the color under the horizon is greyish you should be able to render out as a tiff,  then take your image into Photoshop where you'll notice an alpha channel so you can replace the sky with any texture.
When I was using Maya whilst rendering with MR we had the same issues. The workaround we created was a background dome within the scene that didn’t block or cast any Global Illumination or Final Gather of the sun and Sky - purely for the look and shadows etc.
It would be nice if Revit allowed more advanced features.
Thu, Jul 3, 2008 at 2:04:36 AM | Rendering in Revit 2009
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
or you could bake your ground surface larger.  With modifying your camera angle you should be able to reduce this effect.
or
Photoshop your ground surface to meet the horizon.
Thu, Jul 3, 2008 at 2:42:56 AM | Rendering in Revit 2009
cpbc
3.5 Stars: 3 Votes
Thanks KennyGee. It seems that I had to bring the image into Photoshop then.
Thu, Jul 3, 2008 at 5:06:20 AM | Rendering in Revit 2009
KingRevit
4 Stars: 12 Votes
turn off the sky and use a solid colour say white. then use a decal for you sky, just make a large wall and import a decal onto it.
Thu, Jul 3, 2008 at 8:43:04 PM | Rendering in Revit 2009
cpbc
3.5 Stars: 3 Votes
Thanks KingRevit for your suggestion. I will try it out.
Thu, Jul 3, 2008 at 9:47:40 PM | Rendering in Revit 2009
salarch2
2.5 Stars: 5 Votes
There is a pretty good solution on cadclips.com to use a different background image.  Check it out at:
http://cadclips.com/REVIT-2009-CADclips.htm
Thu, Jul 3, 2008 at 11:48:02 PM | Rendering in Revit 2009
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
The cadclips vid was okbut this is the long way around expecially if you want to adjust your render's. ie. contrast etc  I prefer to use Photoshop as I tend to fancy my images up alot more.  Each to there own........
Mon, Jul 7, 2008 at 1:34:48 AM | Rendering in Revit 2009
cpbc
3.5 Stars: 3 Votes
Hi salarch2. great tricks. tx a lot.
Mon, Jul 7, 2008 at 4:33:33 AM | Rendering in Revit 2009
KingRevit
4 Stars: 12 Votes
nice tip
Sun, Aug 24, 2008 at 9:57:14 PM | Rendering in Revit 2009
JMcLelland
Maybe I haven't dug far enough yet, but I'm surprised not to hear more frustration with rendering in '09.  I've been running Revit for a long time, and I've got years' worth of materials -- and wall, roof, and floor assemblies with those materials applied -- that are now useless.  I've loved every upgrade of Revit until now, but this one is feeling an awful lot like Vista.  Lots of bells and whistles, but so far a big net drag on my productivity.
Tue, Oct 28, 2008 at 3:04:30 PM | Rendering in Revit 2009
Prophecy99
Prophecy99 Avatar
you can say that again ^^^ 09 is really bringing me and my productivity down.
Imagination reveals truths reality obscures.
Tue, Oct 28, 2008 at 3:23:50 PM | Rendering in Revit 2009
#13
tim123
4 Stars: 19 Votes
The line represents the horizon - the sky doesn't come below this.  Export your image as a tiff and reinsert it in revit and put your background sky behind it in a drafting or sheet view.
Wed, Oct 29, 2008 at 12:13:07 AM | Rendering in Revit 2009
#14
will2play
will2play Avatar
Banging your head on your monitor, trying to create a Mitered-Corner Window?  In this week’s Rockstar Hour I'll show you how to create Mitered-Corner Windows.      The Rockstar Hour is a opportunity to attend a free hour of web-based Revit training.
Join the meeting here.
https://www1.gotomeeting.com/register/353233504
Rockstar Hour:
9:30 AM – 10:30 AM PST every Wednesday
See you there,
Know someone else who's been working on this problem?  Connect them with the Rockstar Hour.
Will Harris
www.will2play.com
www.will2play.com
Wed, Oct 29, 2008 at 5:49:42 PM | Rendering in Revit 2009
#15
newnik29
Okay, folks - same topic but new question: I've peppered a siteplan in RAC 2009 with rpc trees. They're easy to use and render out quickly, too. My problem is this: If I tip my 3d image to view it from the top, rendering causes the trees to dissappear. They cast shadows but have no image - just the grass below them.
 How do I get trees to render in a 'top view' 3d view?
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:51 PM
Helping rendering in 2009
Sun, Apr 19, 2009 at 8:25:00 AM
Rendering function greyed out in Revit Arch 2009
Mon, Feb 16, 2009 at 4:53:19 AM
Rendering in 2009
Wed, Jun 11, 2008 at 3:18:09 PM
Rendering And Light Settings Revit 2009 [ 1 2 ]
Tue, Oct 20, 2009 at 3:06:24 AM
26
Page generation time: 17.6082
