Forums >> Revit Building >> Technical Support >> mysterious hole in wall
19 Posts No Rating |
there is a void in my wall that i did not draw and i can't get rid of it... there's nothing there that i can tell that is cutting it. no demo or existing object in the way. nothing above or below that should be cutting the wall this way. you can see this hole in elevation and 3d as well. if i delete the wall and redraw or even just draw a wall next to it, the hole is still there.... help!
23 Posts No Rating |
It looks like you have something turned off or in a different Phase. Also, try clikcing on the light bulb at the bottom of the screen.
i've tried turning on all phases and turning on everything using visibility graphics and the light bulb...nothing's there....
Can you post your file if it's not to big?
Are the wall ends set to allow joins?
file is too big. idk why it keeps posting my same reply over and over again. how do u check that wall join thing?
ok so messing with allowing/disallowing wall joins doesn't get rid of the stupid hole...
Try detaching walls from floor and roof s if you got them.
it's detached from everything
attaching the wall to the ceiling/roof/floor doesn't fix it either...
Are you using design options?
Try setting your Phase to Show All
Applying Materials To Cover A Hole |
Mon, Mar 10, 2008 at 8:26:30 PM
Curtain wall in wall hole |
Tue, Sep 8, 2009 at 7:03:33 PM
Mysterious Notch in Wall |
Tue, Dec 14, 2010 at 4:29:42 PM
cutting a hole in a massed floor/roof |
Mon, May 11, 2009 at 7:07:00 AM
Cutting a shaft wall |
Thu, Nov 29, 2012 at 7:13:39 AM
