30" Microwave which fits over a cooktop adjacent to cabinets left and right. |
20118 Downloads
AutoCad Object downloaded from the Viking Website, the modified into a format which could be converted into a Revit family |
Product Version: Unknown
11579 Downloads
2834 Downloads
simple cooker |
11117 Downloads
Cooktop in steel |
10409 Downloads
forno e fogão a lenha_Oven and wood stove |
4116 Downloads
Commercial Grade Convection Oven |
7355 Downloads
6 burner gas stove
SMEG Design
Revit 2010 |
33812 Downloads
30" Jenn Air Electric Downdraft Cooktop with Parametric Settings for 4 burner setting or Grill and 2 burner. Settings allow you to switch between the left side Grill or double burner.
File Type: Revit 2012 64 bit |
5073 Downloads
3369 Downloads
Microwave |
Product Version: Revit Building 5.1
11704 Downloads
Microwave |
No rating |
10370 Downloads
Microwave |
18143 Downloads
Microwave |
26543 Downloads
This microwave family is for above-range applications. It was loosely modeled after the Samsung SMH6160WB over-range microwave but it is parametric. Subcategories have also been defined. |
75916 Downloads
Microwave Oven |
No rating |
14072 Downloads
NEFF Induction Hob with twin FlexInduction zones.
Based on model T44T63N0 |
4930 Downloads
This is a model of a backyard barbeque, highly parametric, you can open and close the hood, and change many of the finishes. I will also upload the steak model I made to show the grill in action. I will be also loading the rangetop and articulated light for the barbeque as well.
The barbeque has a void attachech so you can drop it on an existing counter and it will cut out the space around it. Its one of my first attempts at building a parametric family. |
Product Version: Revit Structure 2020
18030 Downloads
Oven |
34105 Downloads
Oven |
No rating |
12932 Downloads
Oven - Deck |
No rating |
9667 Downloads
1048 Downloads
No rating |
10480 Downloads
pizza oven - racks |
No rating |
8040 Downloads
Pizza oven - conveyor |
No rating |
4703 Downloads
Enjoy my latest Revit family creation.
Hope this helps people.
All materials modifiable to your requirements |
No rating |
6962 Downloads
1693 Downloads
high efficiency Kuznetsov's Wood Oven
with range and water heater
power 16 kW (area heating ~120 m2)
scheme for building equipment |
No rating |
1082 Downloads
Reference model: Brastemp BFO40N
Parametric materials.
Open/closed top part parameter.
Made entirely with Revit tools. |
Product Version: Revit Architecture 2019
1326 Downloads
Domestic Wood Fired pizza oven. 900 bench height. Parametric Flue height off bench top. Mounted on 100mm thick benchtop which has tapered sides so you can bring your cabinet/walls up to bench height neatly. Based on Zesti brand. |
No rating |
7882 Downloads
