Gas oven for bakeries. |
5913 Downloads
Barbacoa con parámetros para controlar los materiales y con fregadero incluido. |
6148 Downloads
Barbacoa no paramétrica con control de volteo horizontal. |
18456 Downloads
with some mistakes, modeling only by photos and no measures. Revit 2017 |
No rating |
Product Version: Unknown
871 Downloads
For all those in need of a good commercial coffee maker with removable servers |
49335 Downloads
Churrasqueira com forno |
983 Downloads
No rating |
507 Downloads
Churrasqueira em tijolos maciços refratários |
12566 Downloads
Familia de cocina industrial restaurante, parametrizado. Fogones en doble matriz paramétrica, medidas de la isla o mesado y grupo de parrilla grill on/off. |
23200 Downloads
Bunn Bulk 1 lb. coffee grinder |
16846 Downloads
Right guys and girls..... my latest model and this one aint that bad!!
A nice Cooking pan Set based on the Prestige set. Included is a Low Sauce pan, High Sauce pan and Frying pan.
I've modelled 2 of them seperate and loaded them into one.
Looks the biz in a kitchen render!!
Hope they come in useful for you.
Enjoy |
17436 Downloads
Frymaster MJ45 Gas Deep fryer |
Product Version: Revit Structure 2009
16511 Downloads
1893 Downloads
Fogão a lenha típico do interior, produzido pela cia do churrasco. tijolos e placas de Ferro. A burner made of bricks and iron plates |
5969 Downloads
Fogão à lenha/ caipira, totalmente parametrizado. |
2140 Downloads
Basic model of a typical fryer used in commerical kitchens.
400 W x 735 D x 1085 H.
Basket by others.
6543 Downloads
1566 Downloads
Frymaster MJ35 Gas Fryer with Baskets (they are a separate family loaded into the main family) |
8383 Downloads
Morning Peeps.....
My very latest creation and this ones a beauty!!
A 6 burner BBQ based on the Iowa 6 Burner Gas BBQ.
Dimesnions are H)107.5, (W)140, (D)56.7cm.
with a cooking area of (W)77, (D)41cm.
Fixed in size as modelled based on this model but all materials are changeable. Looks rather good in an external render.
Hope you guys like it, i know i've said it before i'm too kind!!
Feedback and ratings welcome.
Cheers and enjoy |
24973 Downloads
4 Pan ceran hotplate with gantry and sneeze guard.
1525 W x 660 D x 535 H. |
1351 Downloads
Bunn iced tea maker with 3 gallon server |
8093 Downloads
the P12 III is the most recent addition to the PROBAT shop roaster series and the next one of a whole new shop roaster generation. Like its smallerequivalent, the drum roaster embodies inspiring constructive accomplishments combined with the iconic PROBAT design.
PROBAT – WERKE von Gimborn Maschinenfabrik GmbHReeser Str. 94D-46446 Emmerich am Rhein / AlemaniaTel.: +49 (0) 2822 912-0,Fax: +49 (0) 2822 912-444E-Mail: info@probat.comInternet: http://www.probat.com |
375 Downloads
marmita, olla. De cerámica, la tapa se puede apagar.
Soup pot, stew pot. Ceramic finish and the top can be turned off.
No rating |
7641 Downloads
Mandelprofi nut roasting machine |
No rating |
40 Downloads
Domestic Wood Fired pizza oven. 900 bench height. Parametric Flue height off bench top. NO BASE ATTACHED - so you have to check the spec sheet to make sure you allow for the correct thing. Based on Zesti brand. |
No rating |
6435 Downloads
RICE COOKER 460Ø x 330H |
6254 Downloads
Hotpot Soup Kettle 11 litres |
No rating |
2093 Downloads
A Steam Table with circular tops, a sneeze guard and storage area underneath. All pieces have parameters to control the materials. Please rate and comment. |
4665 Downloads
A steam table with rectangular tops and space for plating. Every piece has a parameter to control the material. Please rate and comment. |
2965 Downloads
Tapa para dispensador de comida, tipo buffet, para restaurantes.
Chafer cover, for steam table. Food dispensing equipment for restaurants. |
No rating |
1562 Downloads
