Parametric version of the other ADA locker bench available here on RevitCity. Includes option for with or without back rest. Created in Revit 2021 (version picker doesn't go past 2020). |
No rating |
Product Version: Unknown
1074 Downloads
Bleacher sim. to Jaypro 4 Rows Tip and Roll Bleachers.
4 families to adjust length - 7 1/2 ft, 15 ft, 21 ft and 27 ft.
Adjust material for the planks and support. |
22074 Downloads
30647 Downloads
21851 Downloads
Flat bench with barbell rack |
4148 Downloads
Made a foam roller to put in your gym or anywhere else!
Tags:
foam roller , gym equipment , gym , fitness , massage |
8575 Downloads
7980 Downloads
Lifting Bench |
Product Version: Revit Building 5.1
24871 Downloads
Elaborada de un componente de versión 2012. |
No rating |
1158 Downloads
t-bar for lifting |
1197 Downloads
No rating |
6235 Downloads
Standard wight lifting bench without barbell. Bench type has multiple tilt angles. |
No rating |
6409 Downloads
Standard wight lifting bench with barbell. Barbell visibility has instance toggle and bench type has multiple tilt angles. |
6283 Downloads
