This component is used to put 2d lines in a model for closet rod and Hangers It is parametric in length and easy to pull the ends to the length of the closet. |
19556 Downloads
This annotative familiy has adj. arrow head and adj text |
No rating |
Product Version: Revit Structure 2012
1841 Downloads
These Revit Schedules are a room schedule filtered for the room named Attic and a soffit schedule that includes a soffit pretending to be the ridge vent. The soffits model across the whole roof including the eaves to get the required area. The ridge vent is a narrow soffit at the ridge the length of the ridge minus the width of the boundary. I have included the stand alone schedules with no model at www.revitcity.com . The math formulas are in the schedules and can be modified per required code. The formula for the ridge vent is the perimeter of the ridge / 2. The ridge boundary is as narrow as possible so I can get a length value. Conditional values are set to black out the values if the manufacture is not who I need it to be. I think it’s pretty cool. If you have any questions feel free to email me at JustinDesigns3D@gmail.com. Enjoy :-) |
No rating |
1268 Downloads
Here's an updated Floor Finish Material Transition symbol enhanced by Reviteer Extraordinaire StePhen Grant of Austin, TX. Da-Yam, that boy's good!!!
2155 Downloads
A revised version of jterrell's upload. Title now includes scale and changes when new values are entered. Rate it if it helps! |
13871 Downloads
Callout for material transition w/ labels |
No rating |
706 Downloads
No rating |
Product Version: Unknown
1194 Downloads
North Arrow |
21635 Downloads
North Arrow, Box style, reads Left & Down |
No rating |
1295 Downloads
North Arrow with True North |
No rating |
Product Version: Revit Building 6
6135 Downloads
This Family comes with parametric and it was created for showcase purpose. This can be used in Sheets also. |
Product Version: Revit MEP 2018
3416 Downloads
Minimalist Square North Sign with True North and Prayer direction marker all angle are parametric |
1050 Downloads
Parametric graphic scale with respect to the numbers in the scale. The title can be changed as well. Insert the scale into your project and double click the first real number of the scale (20 by default). The other labels will update accordingly. |
28470 Downloads
Please see the attached step by step explanation. |
No rating |
482 Downloads
Many parameters for visibility, lengths & types, including arrows lengths and centre radius. |
3039 Downloads
SPOT ELEVATION WITH LEFT AND RIGHT VISIBILITY + 2 LABELS |
4265 Downloads
Insert this spot elevation as a symbol and you will get the target, the line and 2 labels. The label above the line gives you an elevation in foot-inches. The label below the line gives you an elevation in engineer standards - 100.33' (example) This works great on site plans, when you have to give the real site dimension compared to the architectural dimension you chose. |
Product Version: Revit MEP 2009
8845 Downloads
repeating detail |
No rating |
448 Downloads
