45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
08 33 26 Overhead Coiling Grille
A revised version of another on this site that had issues when the model was "flexed".  Those problems should be fixed in this.
3 Stars from 1 Votes
Product Version: Unknown
4416 Downloads
16' Overhead Panel Garage Door Colonial
3 Stars from 5 Votes
24935 Downloads
4-Panel Double Pocket Door
I updated this to allow for different thicknesses of walls. It will create a 4" interior portion of wall and you can have a 4" (or any size larger) exterior portion of the wall. It's loosely based off Weiland exterior sliding pocket doors. This newer version keeps the model objects visible and does not have symbolic/model lines for plan view.
19339 Downloads
8' Overhead Panel Garage Door Colonial
4 Stars from 5 Votes
16865 Downloads
AGRV_Door_OverheadRollingPlusA_含小門捲簾門A_
with parameters for open/close door in 3D view
Metric Overhead Rolling door + escape door with DIM & Material parameters and dimension Guide
Visit our website AgileRevit.com for more families
826 Downloads
AGRV_Door_OverheadRolling_捲簾門
Metric Overhead Rolling door with DIM & Material parameters and dimension Guide
1917 Downloads
Angular Openable Door
Open at any angler
2803 Downloads
Barn Door - Single Panel dynamic
Residential barn door, single panel with dynamic parameters including open position.  Taken from "Sliding_Barn_Style_Double_Door_14548.rfa" off this site and modified for use.
999 Downloads
Bypass Door
Bypass Door
Bypass Door - Has rail system and can be shown open using a custom percentage parameter.
3354 Downloads
Contemporary Flat Panel Garage Door
Fully Parametric Garage Door
4 Stars from 4 Votes
38864 Downloads
Corner Stacking door
Parametric corner stacking door
4 Stars from 2 Votes
Product Version: Revit Building 9.1
14334 Downloads
flush mounted secuirty grille
This is a modified version of a manufactures coiling grille for recessed mounting for use in retail.  Side track is set to be flush mounted with drywall face instead of surface mounted.  Tube steel backup shown for reference but actual size should be coordinated with your engineer based on opeing size.  The TS 2x2  worked for my small application as a starting poing until the size was finalized by my engineers for a 6' x 10' opening.
 http://www.clopaydoor.com/bimfiles.aspx for large selection from manufactrer
4 Stars from 1 Votes
4857 Downloads
Garage - Glass 2 Car
Fully Parametric
Please Rate
3.5 Stars from 13 Votes
19800 Downloads
Garage Door with Windows
A garage door with a row of windows on the top row.
2 Stars from 8 Votes
Product Version: Revit Structure 2009
66333 Downloads
Garage_Single-Car_4-Lites.rfa
This Garage Family expands on the work by the author of "Garage_Door_2045.rfa" posted on this site; however, this family is now fully parametric and has standard garage door sizes for a single car garage programmed into the file. There is an option to turn the muntins on or off with each individual placement of this door. Standard Door sizes included are 8x7, 9x7, 10x7, 8x8, 9x8, and 10x8. You can add your own sizes as needed.
13349 Downloads
Horse Door
Horse Door
Door for a barn stall
4.5 Stars from 3 Votes
12162 Downloads
Interior double slider barn door
Double Barn door with exposed rail and sliders - most things are parametric and I think I've tested it thoroughly - swap out the door panel to your own if you prefer - has the ability to turn on and off centre crash rail and braces as instance parameters.  Steel single rectangular rail on spacers off the wall, runners connected to stiles.
8058 Downloads
Interior single slider barn door
Single Barn door with exposed rail and sliders - most things are parametric and I think I've tested it thoroughly - my first upload so hope it works - swap out the door panel to your own if you prefer - has the ability to turn on and off centre crash rail and braces as instance parameters.  Steel single rectangular rail on spacers off the wall, runners connected to stiles.
3 Stars from 2 Votes
9268 Downloads
McKeon Coiling fire door
McKeon top coiling fire door with egress pocket door.  The egress door is located in a pocket in the wall and when the system activates, it swings into position and the coiling door drops from above.  This family includes all elements as well as a 'closed' and 'open' position.  It is hosted on a face of a wall, more specifically the back of the pocket where the egress door is in.  Ceiling height and width are instance controlled parameters allowing you to set them specifically for each import.  It includes 2d linework details (copies from McKeon) for both side tracks in plan view and then the coiling mechanism above the ceiling in elevation and section views.
3029 Downloads
Overhead Coiling Door
Garage Overhead Coiling Door
3447 Downloads
Overhead Panel Door
Overhead Panel Door
Overhead Panel garage door in various sizes
2.5 Stars from 10 Votes
15970 Downloads
Overhead Sectional Paneled Door
This is a single residential garage door created with the standard track found in the Clopay revit models.  It is fully-parametric up to 9'-8" wide (based on track restrictions) and with trim that can be turned off.
4.5 Stars from 4 Votes
12573 Downloads
Pocket Door
Pocket Door
Single Pocket Door - Includes all hardware and creates void within wall system similar to how a pocket door will actually be installed.
36587 Downloads
RDR - Security Grill
Parametric Open Security Grill I needed to create, Hope it's helpful. Cheers.
8969 Downloads
revolving door
revolving door
revolving door
11393 Downloads
Revolving Door
Revolving Door
Revolving Door
4 Stars from 3 Votes
Product Version: Revit Building 6
20625 Downloads
Revolving Door
Revolving Door
made to be inserted as a panel in a curtain wall
1 Stars from 1 Votes
6565 Downloads
Revolving door Chrome
Chrome revolving door with glass doors
4501 Downloads
Revolving Doors
Revolving Doors
Revolving Door, aluminum frame, glass enclosure, with solid roof, eight feet tall
15034 Downloads
Rolling Grille Door
Rolling Grille Door
upward acting
3.5 Stars from 4 Votes
Product Version: Revit Building 5.1
21095 Downloads
Page generation time: 0.6719
