2959 Downloads
Non parametric |
Product Version: Unknown
11725 Downloads
Non parametric |
11714 Downloads
No rating |
3523 Downloads
Full funcitonal parametric overhead door with windows.
You can change everything about this door!
Good luck! |
5492 Downloads
The basic Revit single panel door adjusted so door swing is 45 Degrees in plan. Less clutter. |
5589 Downloads
900MM |
4980 Downloads
A Minha Porta |
7856 Downloads
AGRV_Door_2WaySwingSingle_雙向單平開門
Metric 2Way Single Swing door (uneven) with DIM & Material parameters and dimension Guide |
No rating |
648 Downloads
AGRV_Door_HungSlidingSingle_單橫拉門
Metric Hung Sliding door with DIM & Material parameters and dimension Guide |
No rating |
1447 Downloads
AGRV_Door_PocketSlidingSingle_單口袋門
Metric Pocket Sliding door with DIM & Material parameters and dimension Guide |
No rating |
898 Downloads
AGRV_Door_SwingSingleA_單平開門A
(Hinge on the right hand side when outside and facing the door)
Metric Single Swing door with DIM & Material parameters and dimension Guide |
No rating |
507 Downloads
No rating |
306 Downloads
AGRV_Door_SwingSingle_單平開門
No rating |
361 Downloads
Asian Door, parametric dimensions and materials. Revit 2011 version |
13572 Downloads
Revit 2019. This Garage door is compiled from a few different families found on Revit city. |
1243 Downloads
1128 Downloads
Craftsman style entry door with sidelights. Not parametric. Sorry. Don't know if I did it properly. |
24305 Downloads
Designed in revit 2015
36"x80" (non parametric) |
No rating |
7247 Downloads
All finishes are changeable.
Done using Revit 2014
10211 Downloads
1995 Downloads
Curved curtain panel for application in Revit curtain wall systems. Use the "Panel Centre Radius" instance paramter to suite the curve of your wall.
Please rate and comment. Cheers!! |
Product Version: Revit Architecture 2019
2854 Downloads
My first upload for revit family!!! This door family is for curtain wall panel door. Since I can only find sliding door for walls instead of curtain wall. Adjustments are needed to fits to your needs.
(Beginner/Student here... Don't expect too much from me)
Thank You! |
70204 Downloads
For all those who build railings using a curtain wall instead of Revit's mediocre railing tool, this is a Livers Bronze 30" square aluminum panel for non-stair guardrail applications. See website for post attachment.
http://liversbronze.com/railing-systems/panel/ |
25879 Downloads
Curtain Wall Panel With Clamp - Clamp be adjust in visibility mode, so that it will joined nicely at the end of the curtan wall. |
22478 Downloads
no trim |
20644 Downloads
Parametric door
Can be closed and open 45 degrees and 90 degrees |
No rating |
9953 Downloads
No rating |
905 Downloads
Door with multiple parameters to adjust depending on what you need |
No rating |
468 Downloads
Revit 2022
Door family with varrying panels of that style which can be switched with a family type parameter.
Parameters include:
- Width
- Height
- Frame Thickness
- Thickness (door)
- Center Rail Height
- Top Rail Width
- Center Rail width
- Side rail width
- Bottom Rail Width
- Trim Width
- Trim Thickness
- Handle Height
- Handle Inset
- New (instance)
- Existing (instance)
- Undercut (instance)
- Deadbolt On/Off (instance) |
No rating |
541 Downloads
