THIS IS TO BE THE 1322 JELD-WEN DOUBLE DOOR WITH 2 12" SIDELIGHTS. I TRIED TO MAKE IT USER FRIENDLY. BUT SINCE I AM STILL LEARNING, I CAN NOT SAY IF IT IS OR NOT. |
Product Version: Revit Building 9
4647 Downloads
16' Overhead Garage Door - Prairie Design |
Product Version: Revit Building 8.1
17806 Downloads
16' Overhead Garage Door - Stockton Design |
19875 Downloads
16' Overhead Garage Door - Wagon Wheel Design |
10686 Downloads
16' Overhead Garage Door - Waterton 1 Design |
10997 Downloads
16' Overhead Garage Door - Waterton 2 Design |
5978 Downloads
8777 Downloads
A 180 Degree Double Swing door - Parametric |
12702 Downloads
Parametric 2 Panel Slide Door with a Flexble Opening Distance Door Panel and a fixed Panel |
No rating |
Product Version: Revit Structure 2020
806 Downloads
No rating |
362 Downloads
No rating |
333 Downloads
8 Pane Bifold doors, ideal for opening onto outdoor area |
23444 Downloads
AGRV_Door_2WaySwingDouble_雙向雙平開門
Metric 2Way Double Swing door with DIM & Material parameters and dimension Guide |
No rating |
1035 Downloads
AGRV_Door_BypassSlidingDouble_雙推拉門
Metric Double Bypass Sliding door with DIM & Material parameters and dimension Guide |
No rating |
1107 Downloads
AGRV_Door_SwingDoubleUneven_雙平開子母門
Metric Double Swing door (uneven) with DIM & Material parameters and dimension Guide |
No rating |
777 Downloads
AGRV_Door_SwingDouble_雙平開門
Metric Double Swing door with DIM & Material parameters and dimension Guide |
No rating |
709 Downloads
Basic 3-panel hangar door in Revit 2025 |
No rating |
Product Version: Unknown
126 Downloads
Basic 8-panel hangar door in Revit 2025 |
No rating |
74 Downloads
Parametric & easily alterable within the family |
Product Version: Revit MEP 2011
11516 Downloads
No rating |
2029 Downloads
panel - no trim |
No rating |
Product Version: Revit Building 5.1
17539 Downloads
Fully parametric 6-panel by-pass doors. Created using the Single Panel 4 theme. |
No rating |
10539 Downloads
Non Parametric
Created In Revit 2015 |
10529 Downloads
This double door replaces a curtain wall panel. Door width updates to match curtain grids. Door leaf widths are adjustable. Currently one door has a handle. |
33806 Downloads
Works fine in Curtain Wall |
69210 Downloads
7931 Downloads
Fully parameterized double door to insert on a curtain wall |
19299 Downloads
Pintuan-ready to use, parametric door..enjoy.. |
No rating |
12969 Downloads
No rating |
354 Downloads
No rating |
Product Version: Revit Architecture 2019
1841 Downloads
