43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
Adjustable garage door with windows
5 Stars from 2 Votes
Product Version: Unknown
6983 Downloads
BRNO chair - Mies Van der Rohe
275 Downloads
Circular Opening Curved Fill_n_SqTrim
Circular wall opening with Curve Pattern and with or without Trim By Er.L.J.Upadhyay +919919640999q
58 Downloads
Circular Opening Curved X Pattern_n_Trim
53 Downloads
Circular Opening OX Pattern_n_Trim
Circular wall opening with OX Pattern and with or without  SqTrim By Er.L.J.Upadhyay +919919640999q
22 Downloads
Circular Opening OX+ Pattern_n_Trim
Circular wall opening with OX+ Pattern and with or without  Trim By Er.L.J.Upadhyay +919919640999q
25 Downloads
Circular Opening X Pattern Fill_n_SqTrim
Circular wall opening with X Pattern and with or without Sq Trim By Er.L.J.Upadhyay +919919640999
42 Downloads
Dimond Opening + SqBar n Trim
Simple wall opening with or without Grill & Trim
51 Downloads
Door as design in Banglaesh
Bangladeshi Doors
161 Downloads
Door Wall Opening
Door Wall opening family with editable angle
Product Version: Revit Building 9
2809 Downloads
Door with sideplate and overhead light
Full Parametric! You can choose between wood or glass paneel and everything is flexible!
3559 Downloads
Eliptical Opening with Pattern_n_Rect Trim
Eliptical wall opening with  Pattern and with or without Rectangular Trim By Er.L.J.Upadhyay +919919640999
42 Downloads
Gate_Wood
Gate_Wood
DSB Gate in wood with glass in different shapes
3302 Downloads
loggia
loggia
920 Downloads
MAIN GATE
MAIN GATE
length & material parametric
4 Stars from 5 Votes
26809 Downloads
Opening with Lintel
Opening with Lintel
opening with lintel above - fully parametric
Product Version: Revit Structure 2009
3238 Downloads
PARAMETRIC LOUVER
PARAMETRIC LOUVER
IT  IS USEFUL FOR FAN ROOMS AND BATH ROOMS.
4611 Downloads
Pivot Door Parametric
Porta Pivotante 1.50x2.50
3 Stars from 9 Votes
29694 Downloads
Porta_dupla_vidros2x2
it's not perfect but, it's ok...
3.5 Stars from 2 Votes
Product Version: Revit Building 9.1
1376 Downloads
Puerta para garage
1274 Downloads
raamkozijn 2 67 * 114
297 Downloads
raamkozijn 67 * 114
258 Downloads
Rect Opening SqPatternArayed
Rectangular Opening with  Sq Pattern Array and with or without Trim By Er.L.J.Upadhyay +919919640999
65 Downloads
Rect Opening Swapable 10 Patterns Hor & Vert Array
Parametric Rectangular wall opening with 10 swapable Square fill Patterns in vertical & Horizontal Array and with /without sunshed, side fins & sill projection (if not req, simply set projection=0). 10 patterns to choose from. all parts of patterns are auto adjusted according to sq size 100mm to thousans of mm. Materials of diff patterns & Trim can be selected independently. Patterns can be off for clear Sq opening. O pattern is extra in front of main pattern, which can be off from visibility if not req. .-- By Er.L.J.Upadhyay +919919640999
207 Downloads
Rect Opening Twin SqPatternArayed
Rectangular Opening with Twin Sq Pattern Array and with or without Trim By Er.L.J.Upadhyay +919919640999
43 Downloads
Rect Wall Opening Swapable Sq Pattern vArray
Parametric Rectangular wall opening with 10 swapable Square fill Patterns in vertical Array and with /without sunshed, side fins & sill projection (if not req, simply set projection=0). 10 patterns to choose from. all parts of patterns are auto adjusted according to sq size 100mm to thousans of mm. Materials of diff patterns & Trim can be selected independently. Patterns can be off for clear Sq opening. O pattern is extra in front of main pattern, which can be off from visibility if not req. Opening with Pattern Array in both direction will be the next upload.-- By Er.L.J.Upadhyay +919919640999
128 Downloads
Rect Wall Opening With Swapable multy Patterns
Parametric Rectangular wall opening with 10 swapable Square fill Patterns in vertical Array and with /without sunshed, side fins & sill projection (if not req, simply set projection=0). 10 patterns to choose from. all parts of patterns are auto adjusted according to sq size 100mm to thousans of mm. Materials of diff patterns & Trim can be selected independently. Patterns can be off for clear Sq opening. O pattern is extra in front of main pattern, which can be off from visibility if not req. Opening with Pattern .-- By Er.L.J.Upadhyay +919919640999
115 Downloads
Rectangular Opening +SqBar n Trim
31 Downloads
Rectangular Wall Opening +Grill n Trim
93 Downloads
reverse flash window
simple reverse flash window made from yellow glass
245 Downloads
Page generation time: 0.5803
