47 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
2 Way Swing Wood Door
2 way swing door. change angle of swing
4.5 Stars from 2 Votes
8483 Downloads
Barn Loft Access Door
Fully Parametric barn loft door.
6722 Downloads
Blue Heart Glass window
steel chrome plated
Product Version: Unknown
304 Downloads
Cased Opening
Cased Opening
Cased Opening
Product Version: Revit Building 5.1
14734 Downloads
Cased Opening
Cased Opening
Cased Opening
9278 Downloads
Casing
Casing
Revit 2018 Ellipse Passageway Casing_created with door template_parametric
791 Downloads
Casing
Casing
Revit 2018 Arch Passageway Casing_created with door template_parametric
2797 Downloads
doesnt work
doesnt work
3 Stars from 2 Votes
1293 Downloads
Door - Barn Swinging - Parametric
Fully parametric swinging barn door.
2400 Downloads
Door W/ Upper & Lower Vents
single panel door with upper & lower Vents. Completely Parametric. Materials Available. Revit 2025
78 Downloads
51 Downloads
Door With Operable Swing
Here is a door I created with operable swing and materials are listen on the properties and can be changed.
472 Downloads
Double Door
Double Door
A fully parametric door wit changable panels, Architrave, Sill materials.
Product Version: Revit Structure 2013
11679 Downloads
Entrance Door
Entrance Door
Residential entrance door
4 Stars from 5 Votes
21294 Downloads
Front Door Craftsman Style 2 Lights and a Transom
Very parametric door family: adjustable hardware, door panel, width, height, swing, etc.
If You'd like more doors like this, check out this website:
https://revitfamily.biz/
1252 Downloads
Groundworks Sliding Window
Sliding window fully parametric. Take note: bottom panel height happens to be 0 at default.
4.5 Stars from 3 Votes
7435 Downloads
Interior French Doors - Single and Double (RE-POSTED)
I'M RE-POSTING THESE DOORS AFTER FIXING SOME ERRORS.
Fully parametric interior wood french doors with wood frames modified from Marvin exterior door family - adjustable size, swing, trim, muntins, materials...trim can also be turned off to incorporate door into sidelight/transom system (detailed sidelight to come)
For those who want a detailed interior door that makes door details so much easier!
4.5 Stars from 6 Votes
16367 Downloads
Marvin Commercial Clad 1 3/4" Double Doors
Marvin's commercial double door family that is not on their website - created by modifying Marvin residential double door family
1 Stars from 1 Votes
19289 Downloads
Metal Door with louvre
1735 Downloads
Opening
Opening
Opening
4 Stars from 3 Votes
16792 Downloads
Parametric fold up door
Hi, cos i couldn't find any fold up door family, so i made this one myself, hope it can help anyone
Product Version: Revit MEP 2011
11706 Downloads
Porta de madeira com frisos
Porta paramétrica com frisos e maçaneta tipo bola com roseta
Product Version: Revit Building 9.1
1198 Downloads
Single Door
Single Door
A Fully parametric door with changeble panels, architraves, Frames, Sill materials and much more would highly appreciate feedback and improvement
5943 Downloads
Single Door
Single Door
2767 Downloads
slanted wall door
slanted wall door
it have a double panel door which is  inspired from indian architecture
it is fully parametric and adjustable at any sizes and it applies at every wall leaning at varies angle it will apply to it
216 Downloads
window drikip
window drikip
326 Downloads
Window Variable
Window Variable
Window variable width/height
3524 Downloads
Page 1 of 1 |
Page generation time: 0.5532
