Objects
Page 1 of 2 | 1 | 2 Next >>
8' Tudor Style Garage door
Just a quick garage door I made for a project.
Product Version: Unknown
13071 Downloads
9070 Hinged Garage Door
9'-0" x 7'-0" Hinged Wood Garage Door w/ Arch.
26796 Downloads
Arabic Door
Arabic Door
Made this for fun.  Didn't invest in making it parametric.
3 Stars from 2 Votes
4888 Downloads
Arch opening
Arch opening
This is a arch door opening. comes in many sizes
Enjoy
4 Stars from 2 Votes
Product Version: Revit Structure 2013
14582 Downloads
Arched Door
Arched Door
Decent foyer doors. Fully parametric.
4 Stars from 3 Votes
Product Version: Revit Structure 2011
17863 Downloads
Arched Opening
Arched Opening
Arched Opening
3.5 Stars from 6 Votes
Product Version: Revit Building 5.1
14737 Downloads
Arched Opening
Arched Opening
Arched Opening
10609 Downloads
Arched Opening
Arched Opening
Arched Opening
11276 Downloads
Arched Opening
Arched Opening
Fully parametric arched opening for any width or height. Great for custom homes.
5 Stars from 5 Votes
16656 Downloads
Arched Overhead/ Garage door.
Arched overhead/ garage door.
3 Stars from 4 Votes
14107 Downloads
Arched Wall Niche
Arched Wall Niche
Fully parametric wall niche. A window family; adjust height, width, depth, arch height, sill height, depth, thickness, and material.
4 Stars from 4 Votes
12103 Downloads
Arched Window with frame
This is an arched window based on 'Arc_window_with_trim_8359'
Thanks to the original creator. I modified the frame & columns to fit in my project. The window is parametric & you can change its width & height. I noticed that sometimes the frame arch doesnt fit, so I made another parameter for this to fix in each type you have.
5 Stars from 7 Votes
32483 Downloads
Bow opening
Bow opening
Bow opening
1 Stars from 1 Votes
936 Downloads
Carpanel Arch
Carpanel Arch
Revit 2019
Parametric arch carpanel
1339 Downloads
COLLECT Shelf
COLLECT Shelf
B: 245,7 mm
H: 190 mm
D: 40,5 mm
4.5 Stars from 5 Votes
9667 Downloads
Curved Curtainwall Mullion - Sloped Glazing
Adaptive component - allows creation of curved mullions for sloped glazing.Adaptive order is the same as for start-end-radius arc.  *Family is only curved mullion*  You have to make the sloped glazing yourself :)Revit version 2016
3384 Downloads
Curved Sash with glazing bars top & bottom
Parametric sash window with adjustable width, height arch & visiblity option on glazing bars, cill board, cavity barriers
4.5 Stars from 2 Votes
9385 Downloads
Double door
Double door
This is a Double door with a half circle glass window above it. it comes in many sizes.
3 Stars from 1 Votes
13558 Downloads
Double Door
Old School double doors
Product Version: Revit Building 9.1
2454 Downloads
Double Doors with glasses
simple door with glass
雙開-矩形 上玻璃門
Product Version: Revit Structure 2016
5144 Downloads
Fully Parametric Arched Door
Fully Parametric. You can edit all dimensions, and all materials as well.
Enjoy =)
980 Downloads
Irongate_01
737 Downloads
Large Arched Opening
Revit 2017
2754 Downloads
Non-Cased Opening Arch
3 Stars from 3 Votes
19635 Downloads
opening with railing and parametric arch *FIRST UPLOAD* PLEASE RATE AND COMMENT
opening on host wall with a railing set to 100cm, 3,28ft height
overcame by a parametric arch.
Family: Generic Mass Based on Wall
PARAMETRES ARE:
Altezza apice = apex height (I forgot to set this parametres, you have to go on edit family and set it
Larghezza apertura = opening width
Raggio = ray of the arch
once you set the eight, when you get to change ray value, the apex won't change its position.
4133 Downloads
Parametric Arch (or Arc) Profile
This is a Parametric Arch (or Arc) Profile. It will calculate the radius based on the input of the Height and Width. Default Thickness is 1” and can be changed. I will be using this in all my arches for openings, doors, & windows. It also works great for barrel shaped dormers and roofs. It also can be used in horizontal arcs. Enjoy JustinDesigns3D@gmail.com
3108 Downloads
Parametric arched opening
Fully parametric arched opening for use in walls. The width controls the radius of the opening.
Product Version: Revit Architecture 2019
1664 Downloads
Parametric Garage Door
Here's a fancy fully parametric arched garage door with details (Also parametric).
I'm still working on making the radius of the arch parametric - I'll upload it if I ever solve all the problems. Also you can't change the number of panels in the door, but they will adjust themselves appropriately as you change the width of the door.
1 Stars from 2 Votes
20151 Downloads
Persian Arch
Persian Arch
this is horseshoe pointed arch
69 Downloads
puerta deslizable para closet
2146 Downloads
Page generation time: 0.6178
