Fully parametric. Modeled after the Brannen Millwork Euro Frame door, up to the CAD details. Wouldn't go thinner than 6" walls for the frame's sake. |
29282 Downloads
Lean-To Greenhouse Acces Door (Angled) Full Parametric By Juul |
5891 Downloads
Made some quick modifications go here for updated door. |
6836 Downloads
Fully parametric arched door with diamond window pattern. For parameters other than Width, Height and Thickness scroll down. I moved them for ease of changing the critical parameters. Adjustable Swing is an instance parameter. There is also a visibility toggle to turn off the line to making it look like a Dutch door.
Fore non arched door go here
Hope it helps,
smh |
No rating |
3574 Downloads
Wooden arched french styled external glass door |
Product Version: Revit Building 9
12445 Downloads
Arched window can adjust height 1rst 1 so far.... |
4125 Downloads
Parametric |
21416 Downloads
Contemporary/modern style door made at NOHS |
8352 Downloads
no trim with frosted panel in center |
No rating |
Product Version: Unknown
8256 Downloads
aluminum frame |
Product Version: Revit Building 5.1
15926 Downloads
aluminum frame |
No rating |
8888 Downloads
wood frame |
No rating |
10736 Downloads
Download: http://deko.bimobject.com/DEKO-DG-Door
This is an example of one of the many objects available from this manufacturer on the BIMobject Cloud. Click on the link to find so many more objects which are free for all designers from around the world to use. We also have an amazing app which enables you to access our complete library directly from within your BIM software
Revit app: http://info.bimobject.com/revit-app
Single doors are available in module sizes from 700 x 2100 mm to 1200 x 2100 mm, double doors in size 1800 x 2100 mm. Non standard sizes are available to order.
4 or 6 mm clear toughened glass is used for the glazed sections of Deko DG glazed doors. Where specific fire or sound ratings are requried special glass can be inserted.
In the standard format DEKO Doors can be delivered with approval and certification and sound classifications up to 35 dB.
All doors are prefabricated, which eliminates any need for site finishing after installation. All DEKO Doors have been awarded the Danish Indoor Climate Labelling. |
4547 Downloads
Door for CURTAIN WALL PANELS. Model based on Windspec Inc's Series 5000. Comes with a few hardware options.
http://www.windspec.com/pro-entr-500.htm |
31503 Downloads
Single lite door with transom. |
No rating |
1725 Downloads
No rating |
2970 Downloads
Fore arched door go here
Hope it helps,
smh |
1730 Downloads
Fully parametric
Width of sidelight can be changed |
2560 Downloads
This door has a fully parametric sidelite; The door vision panel can be swiched on/off; The vision panel dims can be altered. The door frame size can be altered. The exterior and interior wall wrap can be altered. The door swing can have different angles. http://revitize.blogspot.com/ |
3087 Downloads
This door is Revit 6.1 compatible only. The door is based on formulas from the Stanley catalog with added parameters to control the frame finish and offset from the wall face. |
No rating |
5037 Downloads
This swing works because its faced-based [applied] to the swing plane. Panel types are also swappable and more can be added. Revit 2017 though. Real Extrusions with no symbolic lines. Jamb frame is also resizable so it can be made narrow to simulate a cased door by just adding trim. |
1899 Downloads
Has family types already made for a few different sizes. Totally parametric. |
10648 Downloads
An exterior door with plenty of windows and trim |
22019 Downloads
Frameless glass door - fully parametric (fixed the door handle to the correct side in this version) |
26825 Downloads
GLASS AND ALUMINIUM DOOR |
420 Downloads
PARAMETRIC DOOR AND SIDELITE |
10553 Downloads
A pull glcursedoor with top n bot frame. It is only done for 1000x2000 size. You are welcome to modify it. |
2813 Downloads
This is a single glass pocket door. The door can be changed so the glass is translucent. Sizing is a usual for any Revit object. |
16297 Downloads
Greenhouse Ridge Venting Note: Cannot be smaller then 1' Parametric By Juul |
No rating |
1304 Downloads
Basically the same as the ridge venting but then wall based. Parametric By Juul |
No rating |
1184 Downloads
