fixed-2 |
Product Version: Unknown
6433 Downloads
GARDEN NO.1 VILLA GARAGE DOOR |
50870 Downloads
Almost fully parametric. Height, width, sliding system cover box, frame size on one side, handle height. Frame, door panels, glass panels - materials.
Please leave comments and suggestions. |
36277 Downloads
I modified this original Revit family adding an instance parameter that allows you to slide the door open as much as you need. |
Product Version: Revit MEP 2009
27231 Downloads
Parametric Sliding Door with Editable Multi Panels |
6057 Downloads
Não entendo muito bem de Componentes para Revit, mas consegui criar esta família a partir deste componente: https://www.revitcity.com/downloads.php?action=view&object_id=1962
Na verdade, há uma opção nela que possibilita manter uma abertura e ainda assim os painéis continuam com o tamanho parametrizado. Eu ainda não encontrei nenhum erro, mas se encontrarem ou modificarem, por favor comentem!
Acho que seria bom compartilhar essa opão que eu não havia encontrado até agora. |
5757 Downloads
This is a typical single panel sliding door with glcurse It is my secongd family and should be fully parametric. The hardware is HAFELE rail with guide. |
22570 Downloads
This is a fully parametric single panel sliding door with glcursewith HAFALE hardware (rail & guide). |
42994 Downloads
Made this for a project. I thought it was worthy enough to upload. It is Fully Parametric... so far haha
Materials are for you to change. It's just generic for now!
I created this in Revit 2015 |
6149 Downloads
sliding door |
13558 Downloads
A great door for space planning, early design, existing conditions, & tracing 2D CAD dwgs. ELIMINATES THE NEED FOR DOZENS OF DOORS! Features: Frame automatically adjusts to wall thickness Adjustable door thickness Adjustable width / height width adjustments can be done with the align tool! width & height show up on schedule All parameters are "instance parameters" which cuts down on the need to have dozens of doors in your project. |
26941 Downloads
17520 Downloads
18109 Downloads
panel - no trim |
Product Version: Revit Building 5.1
10598 Downloads
