36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 3 | 1 | 2 | 3 Next >>
180-degree swing door
Product Version: Unknown
10224 Downloads
3 Stars from 1 Votes
5599 Downloads
3 Panel Wooden Door with Trim - Ex Macau 1998
3 Panel Wooden Door with trim based on my office door. Door is Parametric  but is set up for 105 mm thick wall , would need a little editing for thicker walls.
3.5 Stars from 4 Votes
27231 Downloads
3D Parametric Swinging Door with Handle
Parameters include:
Opening Angle, Door Height, Opening Width, Panel Thickness, Jamb Depth, Handle Position, Handle Size, etc.
5 Stars from 5 Votes
Product Version: Revit Structure 2011
15872 Downloads
8030 Arched Wood & Iron Entry Door
NOT parametric... however fits all normal sizes of walls. To change materials, go into nested families.
3.5 Stars from 3 Votes
27435 Downloads
Adjustable Door
Adjustable Door
Adjustable Door
Product Version: Revit Building 9.1
7912 Downloads
Apartment Bedroom Door
The parametric door contains embedded threshold along with standard ironmongery required in a bedroom door.
4 Stars from 8 Votes
23808 Downloads
Apartment ELV-TEL-ELEC Door
The parametric door contains embedded threshold along with standard ironmongery required in a ELV Room, Telecom Room and Electrical Room door.
4693 Downloads
Apartment Front Door
The parametric door contains embedded threshold and number plate which displays apartment number as a value of instance parameter. For further details contact connect@capricot.com or www.capricot.com
4 Stars from 2 Votes
4256 Downloads
Apartment Garbage Room Door
The parametric door contains embedded threshold along with standard ironmongery required in a Garbage Room door.
3901 Downloads
Apartment Kitchen Door
The parametric door contains embedded threshold along with standard ironmongery required in a Kitchen door.
9994 Downloads
Apartment Laundry Door
The parametric door contains embedded threshold along with standard ironmongery required in a Laundry door.
7356 Downloads
Apartment Sauna Door
The parametric door contains embedded threshold along with standard ironmongery required in a Sauna door.
6324 Downloads
Apartment Staircase Door
The parametric door contains embedded threshold along with standard ironmongery required in a Staircase door.
6666 Downloads
Apartment Toilet Door
The parametric door contains embedded threshold along with standard ironmongery required in a Toilet door.
21285 Downloads
Dog Door
Very basic parmetric dog door
534 Downloads
DOOR D-1000
DOOR D-1000
Door with jamb and adjustable door panel
3.5 Stars from 7 Votes
23679 Downloads
door fancy
door fancy
Needed a fancy door so I made this one based on ones from a book, hope you guys like it i've made a few others as well as garage doors so let me know if you want more
9261 Downloads
Door single flush w-lockset, drip edge, cypher lock
910 Downloads
Door Single Flush with Vent
Fully Parametric single flush door with size variable vent.  My thanks to ADesk and RevitCity for guiding me with the tutorial that got me to it. GIVE BACK !!
2.5 Stars from 4 Votes
6536 Downloads
Door-EBE Porte P2FM
Door-EBE Porte P2FM
Door is EBE Porte P2FM available in the US at www.rest-agio.com. Visit the site for full line catalog as well as other luxury finishes from Italy.
Fully Parametric.
11817 Downloads
Door-Interior-Flush
Door-Interior-Flush
Single flush Door with storage system and communication panel_Fully parametric_Textured_Family type catalog
3797 Downloads
Door-Internal-Single_Flush-Hollow_Metal_Drywall_1.1
Single flush Door hollow metal, with two types of door panels (Glass,Louver) and frames (Single rabbet, Double rabbet), fully parametric, textured_Family Types Catalog in attachment. Graphical representation of fire rating is included.
4.5 Stars from 4 Votes
6744 Downloads
door_exist
parametric flush door with plan swing @ 45 degrees
3030 Downloads
DOUBLE FLUSH DOOR W/ HM FRAME AND ADJUSTABLE DOOR SWING
The hollow metal frame will wrap around the wall and will automatically adjust to the wall width.  The door swing angle can be adjusted in the "instance".
4 Stars from 4 Votes
14783 Downloads
DTS_FR_FIRE DOOR_SINGLE_VISION
FIRE RATED DOOR, INFO ON CLEAR OPENING WIDTH. 3 DETAIL LEVELS, SEE JAMBS, PACKER, ARCHITRAVE
3.5 Stars from 2 Votes
8817 Downloads
EP Porte-Filoparete
EP Porte-Filoparete
Door hung flush to the wall with concealed frame.  The latest in door design from Italy.  See it and others at www.rest-agio.com.
Add your own finishes.
2153 Downloads
Flush Door With Design
Fully Parametric Flush Door family. Enjoy with a great door look in Rendering
15718 Downloads
Flush Door with Louvers
Solid flush door with louvers in bottom half
5365 Downloads
Flush Door with Swing Panel
Fully Parametric Flush Door family with Swing panel. Panel can be Swing in any angle and it will give a real open door look in Rendering
9709 Downloads
Page generation time: 23.9856
