40 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
Arched Door (Fixed)
Arched Door (Fixed)
Edited version of the previously posted arched door; in this version, the windows are actually clear.
4 Stars from 10 Votes
34337 Downloads
Double Arch top door with surrounding lites
Custom Door (Very Large)
Product Version: Unknown
2253 Downloads
Double Door with adjustable left/right swing
Product Version: Revit Building 9.1
4376 Downloads
Double Door with Hollow Metal Frame
Double door with HM frame.  The door width is adjustable; each leaf will be 1/2 the width.  The frame automatically adjusts to the wall width.
5 Stars from 3 Votes
4069 Downloads
Double door with unequal leaves
Double flush wood door with hollow metal frame. Adjusting the leaf sizes may cause a little craziness.
3102 Downloads
Double Egress Door w/ HM frame
Double egress door with Hollow Metal Frame that automatically adjusts to door width.
4179 Downloads
Double Egress Doors with Hollow Metal Drywall Frame
Door & Frame Materials, Undercut, Jamb Thickness (for Rough Opening), Open angle (instance)
5 Stars from 2 Votes
5926 Downloads
Double Flush
Double Flush
This door has a fully adjustable swing from 0-180 degrees
1243 Downloads
Double Flush Adjustable Swing
A simple double flush door with an adjustable swing instance parameter. This is based off the double flush door that came packaged with Revit.
3 Stars from 4 Votes
4847 Downloads
Double Flush Door with Vertical Bars
Generic and parametric double flush door witih vertical bars and rectangular frame. Parameters include amount of interior bars and its dimentions, outer frame dimensions, materials, doorknob height and visibility.
Tested and working, 2D Plan represantation ready.
3883 Downloads
Double Flush Doors w/ HM DW Frame
2887 Downloads
Double Flush Double Swing
4058 Downloads
Double Flush Uneven
Double Flush Uneven
This door has a fully adjustable swing from 0-180 degrees and can adjust the leaf size
1372 Downloads
Double Flush Vision
Double Flush Vision
This door has a fully adjustble swing from 0-180 degrees with a flully adjustable window
897 Downloads
Double Timber Frame Door
Door including options to have architraves, door handles (either knobs or levers) and also were these handles are to be located. ie: Only handles to the exterior and architraves to the exterior for a double cupboard door... Also includes the usual adjustable door swing and setback to whether the door is flush or recessed as well as being able to make the doors uneven if wanted.
5 Stars from 4 Votes
22334 Downloads
Double-Flush Vision
Double door with vision panels.  Good for cross-corridor egress path.
1727 Downloads
Double-Flush-Opposing Vision
Double opposing door with vision panels.  Good for cross-corridor egress path, especially in Hospital horizontal exits.
4 Stars from 1 Votes
2522 Downloads
EBE Porte Door-P2FM Double Entry
Double swing doors..Available in the US at www.rest-agio.com
Parametric-Use opening W + H for door size.
3.5 Stars from 3 Votes
24213 Downloads
Flush Double Door - Adj Swing
This double door family is parametric and has adjustable swings.
3.5 Stars from 15 Votes
68352 Downloads
Flush-Double-Door-Adj_swing-w handle
This is a double door that has 3d panel with adjustable swing and door handle.
3.5 Stars from 4 Votes
24034 Downloads
Main Door for houses
1375 Downloads
Multi Lite aluminum pair doors
Adjustable lites in door and finish options
3 Stars from 2 Votes
6999 Downloads
3823 Downloads
Ornamental Front Door
Created at North Oconee High School (NOHS).
A parametric double door with surrounding trim.
Ornamental, Door, Exterior, Front Door
Thank you for looking at my drawing! Leave feedback please.
2 Stars from 4 Votes
7775 Downloads
Perametric Commercial Door Double
This is a perametric single door that can be adjusted to fit the detail level of your project. All components on door and be hiden or revealed through its perameters.
446 Downloads
Victorian Door - Double
2 Stars from 1 Votes
7509 Downloads
Page 1 of 1 |
Page generation time: 0.6130
