68 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
Elevation Head Turkish Standard
This is the elevation tag we use in Turkey. I modified original tag.
4 Stars from 6 Votes
8706 Downloads
Etiqueta para Indicación de Nivel (Vista de Alzados)
Etiqueta para cambiar la clásica figura circular de los niveles en los alzados por una flecha que indica Nivel
5354 Downloads
FAV Elevation Tag
FAV Elevation Tag
Elevation tag that can have a different page number per elevation triangle.  How to load into project:
With this elevation tag family file open and a project file open click on load into project.  Then in the project file, Manage Tab, Addtnl Settings, Elev Tags, it should be in the value drop down box - choose it. Then, duplicate a new type for this new tag.
When you do a new elevation, edit the type and in the Value box of Elevation Tag Graphics choose the little box in the upper right corner that shows up when you select this Value box. Then at the next window choose the duplicated name from the type drop down. FAV Elev Mark or the custom name you created.
3084 Downloads
Left Elevation Target
Left sided elevation target that lets you change the elevation name and elevation number.
Product Version: Unknown
6268 Downloads
Level Head
Level Head
Lo que hice con este Level head fue cambiarle el tamaño de la letra
4 Stars from 1 Votes
3774 Downloads
Level Head - Waterline
This is a Level Head Annotation used to represent a waterline.
4.5 Stars from 2 Votes
4513 Downloads
Marcador para Alzado (Elevation marker Body)
Cuerpo para marca de alzado, la marca incluye Texto de Etiqueta para:
Nombre de Vista
Número de Detalle
Número de Plano
Nota: Lo he vuelto subir, ya que se parametrizo el objeto, ahora pueden manejar visibilidad de contenido
3233 Downloads
NCS Level Head
NCS Level Head
This ia a level head built with the NCS dimensional criteria
2737 Downloads
NCS Level Head
NCS Level Head
THis ia a level head designed with the NCS dimensional criteria
3115 Downloads
NIVEL ELEVACION
NIVEL ELEVACION
ajustado al tamaño que utilizo en CAD
828 Downloads
plan - spot elevation
elevation - spot elevation
turn leader color to white for better result
1 Stars from 1 Votes
2698 Downloads
Right Elevation Target
Right sided elevation target that lets you change the elevation name and elevation number.
3046 Downloads
Spot Elevation Detail Symbol with Draggable Lines
Spot Elevation created as a detail component, so you can place it in drafting views AND drag the end lines. Comes with visibility checkboxes to hide the left or right side leader line. Rate it if it helps!
5765 Downloads
Page 1 of 1 |
Page generation time: 0.3078
