415 Series Aluminium Louvres |
Product Version: Revit Building 9.1
10448 Downloads
The ceiling vent is 8 inches wide and length is parametric. Size of trim and bracing, and materials are also parametric. |
No rating |
Product Version: Unknown
9900 Downloads
Arch Head Louver with Brick Arch Trim |
10307 Downloads
aluminim/wood solar shades |
22089 Downloads
This is a ceiling opening vent with simple rectangular bars across, based on the one on the ceiling I was modeling. It is very parametric. You can change the width and length of the vent, the width and distance bewteen bars, trim width and bracing depth.
4035 Downloads
fixed a glitch. |
No rating |
567 Downloads
The door was modeled open so it can be used as an opening or decorative piece. Fully changeable materials and dimensions. Feel free to edit the family once downloaded.
P.S. There were so many pieces to this family that some parameters might not be set up correctly so changing the height or width might cause problems. |
12042 Downloads
Metal framed gate with vertical metal tube pickets and decorative cross brace. |
31641 Downloads
This Door is not hosted to a wall. It was desigen to stand on its own. Vertical bars are spaced equaly at ±4" depending on the width.
Rvt 15
Hope it helps
smh |
No rating |
5213 Downloads
HAT VENT FOR ATTIC VENTILATION |
5887 Downloads
This louver is fully parametric; adjust length, angle and thickness of louver. The family automatically calculates the number of blades needed to fill the opening. |
32586 Downloads
Fully parametric
Ht,Width,Materials can be Adjusted |
9258 Downloads
No rating |
675 Downloads
I added a simple parametric frame to the louver created by JFazz1 |
5341 Downloads
louver ~120 cm |
6901 Downloads
louver ~260 cm,
made in v5 before array in family was introduced |
No rating |
4044 Downloads
Fully parametric louver with V-blades; adjustable width, thikness, blade number, blade thikness, distance between blades; automatically calculated hight; textured. Please, use this model in a door panel creation (generic model). |
6299 Downloads
One unit metric louvre bay - blades are set every 15cm - blabes inclinaison is parametric - simple model not very detailled
Jalousies ou louvres parametriques sur chassis simple - lames de 15 cm - modele simplifie suffisant jusqu'au plan d'execution
7189 Downloads
This door window fimily is dedicated to our PM Shri Narendra DD Modi
Nested door having 1 wooden door/window frames & 4 door panel choice. Wooden frame can be single or double rebate. If you do'nt need ventilator- simply set the vent Ht to zero. Solid flush door can be conveted to stile n rail panel door by using mould thickness. Multi lite door can be 1V x1H to 10v x 4H lites of glass or other solid material. There is a extra frame(2ndry frame) arroun multi lites, who's width can be zero if you do'nt need it. etc. etc. By adding param of Left or/& Right window with one can win frame also . No leaves are added in window frames to avoid the heavy size of the family. Lallan Ji |
No rating |
1051 Downloads
Fully parametric Trim on frame-(2) Parameters Trim width and trim profile width. Face based model.and two material finishes. 1-Louvre Trim and (2) Louvre Slats. Family members in size from 1' to 3' wide in 2" increments |
4199 Downloads
This is a sample of a parametric aluminum louver with correct section and how it should really be drawn in actual construction. I have to create this because I have not found any louver that is drawn right and with proper draining system. Other parametric louvers posted in revit city got major errors. Bare with this one cuz I downloaded, revised & customized it for only a couple of hours but tested it and it seems okay. |
13352 Downloads
Porton metalico de ingreso, parametrico en altura y ancho, se ajustan la cantidad de tubos internos de acuerdo al ancho del mismo (Metal gate entry, parametric in height and width, fit the amount of inner tubes to the width of the same) |
25726 Downloads
No rating |
764 Downloads
No rating |
452 Downloads
No rating |
469 Downloads
A parametric ceiling vent that splits the air both ways. You can change width, length, trim width and depth, bracing width and depth. You cannot change spacing or size of louvers. Also, width must be at least 1'. |
6415 Downloads
Parametric Round Louver w trim. |
3570 Downloads
No rating |
3864 Downloads
A Parametric Line Based Louver System |
9238 Downloads
A simple louver system that can be customized to fit almost any scenario on a flat surface.
Number of Louvers based on Baseplate Length |
9695 Downloads
