41 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 1 |
5 Switch Decora Light Switch
5 way switch Decora style Light switch
2994 Downloads
Card Reader Wall mounted
Card Reader Wall mounted for security adjacent to a door or secure opening
3 Stars from 2 Votes
7008 Downloads
Code Blue
Code Blue
Wall Mounted Code Blue Switch for hospital or healthcare communications
3182 Downloads
complete parametric electrical componet family
I have been working on this family for several months...   It is fully parametric, has a instant label parameter.  There is a symbol for locating a componet at a special height (re: set at 42" symbol).   I often label a swich componets, for example: Fan, lights (#of lights), dimmer.  The text type has transparent background.
4 Stars from 7 Votes
5308 Downloads
Fire Alarm Pull Station Box
A Non-Hosted Fire Alarm pull station, Red box with White Lettering, set at 3' - 6" AFFL
12586 Downloads
High Voltage Disconnector Switch 115kV
High Voltage Disconnector Switch 115kV View in You tube.
https://www.youtube.com/watch?v=pH84uEwK_Ow&t=1s
 By Rosmer Ocando
Product Version: Revit MEP 2018
476 Downloads
Industrial Socket with Switch
3 Phase Industrial Socket with Switch. (IT Racks, Kitchen Equipments and can be Cable Tray Mounted).No of phases and family category can be adjusted.Make sure you add 2D Annotation separately for floor plan.
Product Version: Revit MEP 2019
668 Downloads
Light Switch
Light Switch
This Family combines a fully realistic renderable Switch and all the capabilities of a MEP Family.  Each Switch can be scheduled and tied to in MEP.
4.5 Stars from 2 Votes
2780 Downloads
Light Switch - Parametric
Typical light switch, modelled with realistic 3D representation, and 2D symbolic representation. Carries a Yes/No parameter to change between a single, double, or triple switch.
5 Stars from 3 Votes
17934 Downloads
LS 14-V 4xLight Switch
True Revit 3D Face Based 4gang Architrave Light Switch complete with render materials for all faces plus electrical connectors and 2D plan switch symbol.
drawn by www.electricalrevitfamilies.com
Product Version: Revit MEP 2009
2283 Downloads
Occupancy Sensor
Occupancy Sensor w/ switch connector,  w or w/o ambient light sensing
Product Version: Unknown
3253 Downloads
One Way Light Switch Symbol Family
You can adjust the scale from edit type, I set it for easier use but the limit size of how small it can be set to is 0.8. Hope it'll be of use!
535 Downloads
Outlet and Switch
Outlet and Switch
***BROKEN***
***MADE IN REVIT 2014***
Fully parametric outlet family. Three types of outlets and power switches in 3D geometry and 2D for elevation and plan views. All included in one family.
Inspired by LK Fuga
5 Stars from 4 Votes
5159 Downloads
Outlet and Switch
Outlet and Switch
Inspired by LK Fuga
3.5 Stars from 6 Votes
9753 Downloads
Parametric Switch
Parametric Switch
Array which starts with one unit !
2374 Downloads
Pull Cord Switch
Pull Cord Switch
Based on MK 3151 WHI pull cord with either MK 2051 WHI or MK 2056 WHI (neon).
Product Version: Revit MEP 2012
911 Downloads
ring VIDEO DOORBELL
ring VIDEO DOORBELL
RING VIDEO DOORBELL
3.5 Stars from 3 Votes
1550 Downloads
Switch - Double
Switch - Double
Double Switch refined from library to include 3D representation and elevation symbolic lines.
12700 Downloads
Switch - Generic (not face based)
Useful when you want to host them onto a casework or anything, not necessarily a wall.
897 Downloads
Switch - Single
Switch - Single
Single Switch refined from library to include 3D representation and elevation symbolic lines.
12607 Downloads
SWITCH MULTIPLE USE
SWITCH MULTIPLE USE
THIS IS A 7 IN ONE SWITCH
THE 7 TYPS ARE REG SWITCH, THREE WAY, FORE WAY, KEY OPERATED, DIMMER OPERATED, 5-30 MIN TIMER AND 10-60 MIN TIMER
3379 Downloads
Switch/deco-lite
Switch/deco-lite
****REVIT 2014****
S/SS/SSS
120V
484 Downloads
X
X
1 Stars from 2 Votes
178 Downloads
Page 1 of 1 |
Page generation time: 0.4797
