35 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
18x4 wire basket 40"dia sweep
This is the corner for the 18x4 wire basket
4 Stars from 5 Votes
Product Version: Revit MEP 2010
1458 Downloads
2 Voice 2 Data Outlet
Duplex Voice - Data Outlet with four jacks.
2151 Downloads
3 Voice 3 Data Outlet
Duplex Voice - Data Outlet with six jacks.
1665 Downloads
Abanico/Ventilador de pedestal- Pedestal fan
Abanico de pedestal. 0.51m x 1.33m.
Product Version: Unknown
416 Downloads
92 Downloads
48 Downloads
30 Downloads
55 Downloads
Product Version: Revit Systems 1
67 Downloads
171 Downloads
AntennaTelecom
AntennaTelecom
AntennaTelecom
1817 Downloads
Cisco 2960 Switch
Cisco 2960 Switch
Cisco 2960 Switch
1817 Downloads
Classmate Service Control Panel (for Classrooms)
This is useful for anyone that works on school projects. This is an "all-in-one" control panel we use for classroom applications, thought I'd share this with the RevitCity community. My model contains a clock, PA speaker, phone, light swtiches, operator switch for PA, duplex receptacle & data outlet; these can be mixed and matched based on your needs.
4.5 Stars from 2 Votes
5265 Downloads
Dell T3500 Workstation Tower
Fully modeled in Revit!  Used in healthcare setting or architect's office.
Visit my RevitCity page for more healthcare models!
1970 Downloads
Droid X
This is the Droid X by htc
289 Downloads
Emergency door unit
Emergency door unit
Emergency door unit from CQR (UK)
This one is with plastic cover.
3 Stars from 1 Votes
1314 Downloads
Emergency Recessed Spitfire Light
Thomas & Betts (AUS) ceiling based recessed 85mm dia emergency light with 240V, 10W, 6V bulb, ceiling fixture only, no battery, has model text for reflected ceiling plan view. Photometrics may need to be changed for rendering as the fitting is set for light.
1609 Downloads
Emergency Recessed Spitfire Light 240V
5402 Downloads
External Termination Point (ETP) fibre optics - PDL56E1-S - NZ
PDL  56E1-S external termination point  (ETP)  fibre optic cable to the home  (FTTH) wall box.
Wall based,  white plastic single gang enclosure.
MEP connection -  communications.
CBI (NZ) 78-11  -  cable communication systems
Revit 2018
509 Downloads
Firealarm manual alarm
Norwegian standard for a manual fire alarm. This is from Apollo (UK) producer.
3.5 Stars from 4 Votes
2927 Downloads
Flat Screen Television
Flat Screen Television. Can be mounted on wall.80"
1.5 Stars from 12 Votes
93354 Downloads
Hand dryer trial
Hand dryer trial
Product Version: Revit MEP 2019
101 Downloads
Headwall Outlet - Med Vac
generic model (not wall based)
2532 Downloads
Headwall Outlet - Oxygen
generic family (not wall based)
2201 Downloads
Horn Strobe Fire Alarm Device Simplex
Simplex, True Alert Adressable Notification Appliance, Horn Strobe.
4 Stars from 3 Votes
4438 Downloads
HVAC_Ductwork_Airzone_Motorized-Plenum_Daikin_Low-Profile_4-Dampers
26 Downloads
Industrial Socket Unswitched
3 Phase Unswitched Industrial Socket. (IT Racks, Kitchen Equipments and can be Cable Tray Mounted).No of phases and family category can be adjusted.Make sure you add 2D Annotation separately for floor plan.
553 Downloads
IT Rack 800x800mm
IT Rack 800x800mm
ICT/CCTV/IDF/MDF Rack - Data Devices
2640 Downloads
IT-800 x 1200 Rack
IT-800 x 1200 Rack
ICT/IDF/MDF/CCTV Rack
2244 Downloads
Outlet - Data
Outlet - Data
Data Outlet refined from library to include 3D representation and elevation symbolic lines.
5 Stars from 5 Votes
15515 Downloads
Page generation time: 1.6103
