34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 2 | 1 | 2 Next >>
40mm Casement window
this is a 40mm casement window modeled off the Vantage profile, all elements are extruded profiles right down to the neoprene seals, this file is quite large but excellent for showing that extra detail in your project.  I think i've managed to iron out all the kinks, and yes this window is parametric.
3.5 Stars from 7 Votes
22538 Downloads
40mm Double Casement Window - adjustable pane widths
this is a fixed 40mm double casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is fully parametric.  One awning & one fixed pane - both panes have adjustable widths
3.5 Stars from 4 Votes
19901 Downloads
40mm Double Casement Window - even
this is a fixed 40mm double casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is parametric.  One awning & one fixed pane - even
4.5 Stars from 5 Votes
26859 Downloads
40mm Triple Casement Window - Adjustable
this is a fixed 40mm triple casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is fully parametric.  Two awning & one fixed pane - adjust awning window widths in element properties dialogue & this ultimately defines the fixed central pane.
3 Stars from 7 Votes
53902 Downloads
Andersen Awining Single
3 Stars from 2 Votes
Product Version: Unknown
4850 Downloads
Cutain wall window - halfly opened
its parametric and then we control the swing angle too and we can assign materials instantly
2737 Downloads
fazerneil 1
fazerneil 1
simple casement window no mullions or transoms
2383 Downloads
Floor Height Multipanel Casement Window
Floor mounted aluminum storefront windows.
Has emergency ADA escape hatch casement.
1562 Downloads
Guillotine window
Guillotine window
Wooden window with casement
1.5 Stars from 2 Votes
15778 Downloads
Guillotine Window Updated
This is an updated version of my Guillotine Window, created for a restoration project at Istanbul.
Hopefully parametric.
2527 Downloads
JM - Basculante 1 Folha c Vidro Liso
Portuguese Window.
100 % Paramétric
Enjoy
3203 Downloads
Kamals Frameless Double Hung Window
242 Downloads
Kamals Plane Frameless Glass Window
343 Downloads
Kamals Single Frameless Glass Window
414 Downloads
Marvin Clad Casement
First upload
1 Stars from 1 Votes
1417 Downloads
One Panel Window
One Panel Window
One panel window to be used as desired. Comment/rate.
16931 Downloads
Parametric Casement Window
Revit Version 2022
431 Downloads
single hung
single hung
single hung window
8867 Downloads
single hung with transom
4 Stars from 1 Votes
2297 Downloads
single hung with triangle
single hung window with mulled triangle on top
3677 Downloads
single hung-2 with transom
double mulled single hung with mulled double transom
1308 Downloads
single hung-3
single hung-3
triple mulled single hung window
2971 Downloads
single hung-3 with transom
triple single hung mulled with mulled transom abv
1701 Downloads
SINGLE HUNG/FIXED/SINGLE HUNG
TRIPLE MULLED WINDOW WITH FIXED WINDOW IN THE CENTER WITH A SINGLE HUNG MULLLED TO EACH SIDE. CAN MAKE ANY COMBO WITH THIAS FAMILY
5525 Downloads
Treatment Room window
Window for a treatment hospital room.
4103 Downloads
Universal Parametric Windows with Masonry Inset
Try it, use it, love it!
And please give me advices for further dev. ;)
You can donate at http://revititthon.blogspot.com
906 Downloads
UOT - Kamel - Window - Fixed and Movable
UOT - Kamel - Window - Fixed and Movable ... Building and Construction Engineering Department ... University of Technology ... Baghdad, Iraq ...
1745 Downloads
UOT - Kamel - Window - Small and High
UOT - Kamel - Window - Small and High ... Building and Construction Engineering Department ... University of Technology ... Baghdad, Iraq ...
2578 Downloads
Ventana de 1 hoja abatible (Single hung window)
Ventana abatible de una hoja / Single hung window
Más familias / more families: shop.a3d.es
3 Stars from 1 Votes
2271 Downloads
Ventana fija (Fixed window)
Ventana fija (vidrio con marco)  / Fixed window
1837 Downloads
Page generation time: 0.6670
