I needed this window for my project. So I created this. Please give feedback. |
17913 Downloads
Andersen Csmt Dbl CR24-CW245 |
Product Version: Unknown
5658 Downloads
These Indian style archtop framed windows are created as per actual elements in use.
Banarasi archtop framed Windows
1 Wooden frames are created from wood log section per design of CPWD India. the design prevents plaster damage around door window frames when face flushed with wall face. Insert in frame may be removed by using insert=0. A chanel is made all aroun middle of frame to hold a perforated 6mm dia pipe to inject pest control liquidin it periodically, to protect door frame from termite etc. Arch height is set to vary in a limit & same for window width as well.
2 Multy lite shutter can be utilise for one fully glazed panel to multy lite, simply by adjusting the vertical & horizontal numbers.
3.All shutters are provided with 2D & 3D swing. Window shutters are out swing as used in Indian culture.
4. use families after studdying the parameters. Window width is restricted as per actual use.It is better to handle the family after loading in project.
5. Any querry can be done on my phone number 91 9919640999 Welcome for further help. |
No rating |
114 Downloads
2 Multy lite shutter can be utilise for one fully glazed panel to multy lite, simply by adjusting the vertical & horizontal numbers. Lower vent can be remove simply by setting lower lite ht to zero.
No rating |
88 Downloads
No rating |
89 Downloads
No rating |
124 Downloads
No rating |
91 Downloads
adjustable both height and width, although number of upper windows does not change, but are evenly spaced and sized |
11085 Downloads
Doubled panel window and then fully parameric and we can control swing angle too |
2514 Downloads
No rating |
3287 Downloads
Finestra doppio vetro a due ante parametrica di varie mosure trasformabile in portafinestra |
1218 Downloads
1122 Downloads
329 Downloads
Go to www.kolbe-kolbe.com for a zip file of all our Kolbe SketchUp Ultra Series Radius models. |
No rating |
526 Downloads
No rating |
891 Downloads
No rating |
771 Downloads
No rating |
683 Downloads
No rating |
661 Downloads
979 Downloads
966 Downloads
799 Downloads
No rating |
1326 Downloads
No rating |
997 Downloads
No rating |
482 Downloads
No rating |
475 Downloads
No rating |
746 Downloads
No rating |
504 Downloads
Go to www.kolbe-kolbe.com for a zip file of all our Kolbe SketchUp Ultra Series Sterling Double Hung 1-Wide models. |
No rating |
2264 Downloads
Go to www.kolbe-kolbe.com for a zip file of all our Kolbe SketchUp Ultra Series Sterling Double Hung 2-Wide models. |
No rating |
1998 Downloads
Go to www.kolbe-kolbe.com for a zip file of all our Kolbe SketchUp Ultra Series Sterling Double Hung 3-Wide models. |
No rating |
1506 Downloads
