No rating |
Product Version: Revit Building 9
1427 Downloads
Parametric Arched Shutter - Boarded (wallbased) Controls:
- Window width x height x drop
- # of boards, board spacing
- Cross boards spacing, middle cross-board
1550 Downloads
No rating |
Product Version: Unknown
789 Downloads
No rating |
504 Downloads
Parametric "openning" Shutters.
Variable height, width, depth, angle |
6644 Downloads
Steel anchoring fixture for glass panels in walls or railings |
No rating |
Product Version: Revit Building 9.1
5513 Downloads
No rating |
6203 Downloads
Horizontal trellis for external facade. Fully Parametric. |
8537 Downloads
Vertical Louver for external facade. Fully Parametric. |
17308 Downloads
Window louver frame fixed onto the wall face. |
No rating |
1421 Downloads
This has a fixed number of Mini Blinds. You can control the width and the head height. Material adjusts from properties. |
2002 Downloads
oculus w/ wrought iron detail |
No rating |
2050 Downloads
Product Version: Revit Structure 2017
8468 Downloads
NOHS / OCHS |
No rating |
1855 Downloads
Hung from above supports, most often roof structure, this fully paramatric window louver keeps the harmful UV Rays off of your building. This is my first upload and one of my first parametric designs. Some of the parameters are type based and some of them are instance based. Please download to find out! Constructive Critique Comments are welcomed! |
9336 Downloads
CRL (C.R. Laurence) HRF 14 BS rigid combination fastener with custom 4 point spider anchor. Can be used with varying glass sizes from 1/2" to 1 1/16" and variable system depth.
http://www.crlaurence.com/crlapps/showline/offerpage.aspx?Productid=41982&GroupID=21214&History=39327:9307:13453:14103&ModelID=21214
9920 Downloads
http://www.crlaurence.com/crlapps/showline/offerpage.aspx?Productid=41982&GroupID=21214&History=39327:9307:13453:14103&ModelID=21214 |
8087 Downloads
2 Panel Quarter Arch top shutter with beveled panels. Fully parametric. Arch based on 2" per foot of width. |
2933 Downloads
Wood Shutters w/ pannel effect and iron nail detail made for a 4' x 4' window but family can be edited |
9988 Downloads
These shutters are wall based for easier placement. The material, number of slats & bands, width of slats & bands, and slat spacing are all parametric. Hope it helps! |
1502 Downloads
No rating |
401 Downloads
No rating |
799 Downloads
