Fully Parametric |
14562 Downloads
Fully Parametric |
8748 Downloads
10 equal part with different size cord and web |
Product Version: Revit Structure 2012
9220 Downloads
Fully Parametric Pratt Truss with Vertical End Members. |
Product Version: Revit Structure 2014
15313 Downloads
250 Grd CHS Beam |
Product Version: Unknown
7585 Downloads
Parametric 3/4"Ø A325 Heavy Hex Bolt. Grip is an instance paramter. Based on grip, formulas determine bolt length and weight (shared parameters) which allow for scheduling and more importantly, bolt list with bolt lengths. Parametric void to cut hosted framing. Bolt visibility paramters are also in place plus an instance parameter for a welded nut (moves the washer to the bolt head side of grip) Based on Portland Bolt specs. Revit 2012. |
15777 Downloads
350 Grd Gal Tube CHS |
4504 Downloads
350 Grd SHS |
6355 Downloads
350 Grd Ultra Pipe CHS |
4394 Downloads
4873 Downloads
4 equal part with different size cord and web |
No rating |
6070 Downloads
450 Grd SHS |
3905 Downloads
Parametric A325 Heavy Hex Bolt Assembly. This bolt is set to 3/4"Ø by default, but also contains 1/2"Ø, 5/8"Ø, 7/8"Ø, 1"Ø, 1-1/4"Ø & 1-1/2"Ø sizes. Based on Portland Bolt Specs. Revit 2012. |
11139 Downloads
Engineered floor truss that will conform to the length of the structure. |
Product Version: Revit Building 9
4752 Downloads
Adjustable wind brace portal frame for Pre-engineered Metal Buildings. |
4972 Downloads
A fully adjustable metal building frame with web stiffeners and baseplates |
No rating |
7562 Downloads
Fully adjustable metal building rigid frame with optional eave extensions. |
4681 Downloads
No rating |
1319 Downloads
Product Version: Revit MEP 2010
2674 Downloads
No rating |
1491 Downloads
No rating |
1623 Downloads
No rating |
1023 Downloads
this was made for the outside of a building, it inside a square 5210x5855 though the componants are grouped so easy to customise |
No rating |
3187 Downloads
3192 Downloads
Single Flute of B-Deck. (Simplified) Created as a structural beam. Ends are adjustable. Allows 3d manipulation. Array to create a panel of B-Deck. (Join to remove joint line.) Intended more for exposed material as a design element. Don't use for large expanses or it will suck up your memory. |
10609 Downloads
Base Plate Connection - Double Row. Fully configuable, plate size, plate thickness, bolt location, bolt size, bolt spacing, number of bolts, grout pad thickness etc. Required to be hosted to an element (ex. beam or column) or a workplane. |
Product Version: Revit Structure 2013
12204 Downloads
Base Plate Connection - Single Row. Fully configuable, plate size, plate thickness, bolt location, bolt size, bolt spacing, number of bolts, grout pad thickness etc. Required to be hosted to an element (ex. beam or column) or a workplane. |
No rating |
5013 Downloads
Base Plate-2 Hole |
No rating |
658 Downloads
A simple beam with two differents sections at the ends
Possibility to replace section profils
Poutre à section variable
Profils modifiables à chaque extrémité |
1501 Downloads
No rating |
1015 Downloads
